02 gmc sierra wont shift into park - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 1st, 2011, 03:30 PM   #1
mokerlund17
mokerlund17's Avatar
Send a message via AIM to mokerlund17
Default 02 gmc sierra wont shift into park
my 02 sierra 4x4 just randomly decided it doesnt want to shift into park today never had a problem before now. you can shift it up into park but the indicator says reverse and the truck still rolls, but i can roll underneath it and push the linkage the rest of the way into park. any advice is the linkage on these adjustable
mokerlund17 is offline   Reply With Quote
Old September 1st, 2011, 04:07 PM   #2
1slo_camaro
LONG STORY SHORT, IM 23
1slo_camaro's Avatar
i dont believe its adjustable. i noticed my old 700r4 cable stretched out and park was hard sometimes and it was hard to get in low 1. i would see if anyone you know might have an extra cable you can try. but if you can shift it from underneath then it shows luckily its not the trans. either the cable stretched out or something with the shifter on the column itself.
1slo_camaro is offline   Reply With Quote
Old September 1st, 2011, 04:22 PM   #3
capndaveyj
yea no adjustment probobly needs a new shift cable
capndaveyj is offline   Reply With Quote
Old September 1st, 2011, 04:30 PM   #4
jbsjunk
Little Member
jbsjunk's Avatar
I have a friend that this happened to. Ends up the shift cable outer jacket fell apart enough where you couldn't get park no matter what you did. Put a new cable in and all was well.
Old September 1st, 2011, 07:54 PM   #5
mokerlund17
Awesome so how do these things work does it run all the straight to the steering column or what? What's the best way to change it
Old September 1st, 2011, 08:28 PM   #6
jbsjunk
Little Member
jbsjunk's Avatar
The column is fairly easy. Look at the new cable to see how it attaches. Follow it under the carpet and pull the drivers seat out to get to the hole it goes thru in the floor. the trans end is easy, pop the cable off the trans, pull the clip on the cable mount and press the sides in to get it loose. Reverse to install.
Might have had 1/2 hour in my buddy's.
Old September 2nd, 2011, 06:14 AM   #7
mokerlund17
Cool thanks for the advice
Page generated in 0.18018 seconds with 44 queries
