2000 chevy tcase with floor shifter - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 31st, 2011, 03:55 PM   #1
tctrojan17
Sexy and I know it.
tctrojan17's Avatar
Default 2000 chevy tcase with floor shifter
I do not have all the info but most of it. I friend of mine has a 2000 chevy silverado with the floor shift transfer case. I have not looked at it yet but is there any reason a np241 out of a 94 chevy would not work for them? What issues would they have? Need to get this thing up and running for as cheap as possible and if a np241 will work then they will save a ton of money. They are not concerned if a light or something will be on in the dash as long as it drives and moves.
Thanks
tctrojan17 is offline   Reply With Quote
Old August 31st, 2011, 09:06 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
what model truck? 1/2 3/4 or 1 ton? new body or old body style?
Old August 31st, 2011, 10:07 PM   #3
tctrojan17
Sexy and I know it.
tctrojan17's Avatar
1/2 ton new body style. I thought the 241 will bolt up to it i just am not sure about anything else as far as sensors and what not.
Old September 1st, 2011, 07:03 AM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i'm pretty sure they will swap in. as long as the donor truck had a 4l60e it should bolt right up. there is only 2 things you have to swap in off the existing t-case. VSS and the 4wd switch.
Page generated in 0.41089 seconds with 35 queries
