F-250 Super Duty tow rig upgrades and maintance build - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 17th, 2012, 06:04 PM   #101
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Originally Posted by MilwaukeeF350 View Post
What glow plug relay you bought?
For those people who got less mpg. Check fuel filter housing and gas tank to make sure it not leak diesel.
I bought an auto zone special for $50 but it has a lifetime warrenty. This is probably my 4th relay in 3 years, my truck hates the cold and I usually get about a year out of them.
I still need to do an oil change this week, new fuel filter as mine is leaking, new shocks, rear hub seals, change all fluids and maybe get a new valve body for the trans and a bigger trans pan.
I'm the man in White.
Old January 17th, 2012, 06:11 PM   #102
MilwaukeeF350
Dan
Yes that what I am worry. Don't feel like replace glow plug relays every 7-8 months.
You should get 5w40 Shell T6 synth it best stuff I had done on mine with 221K miles that Previous owner never really care about maintain. Full of sludge in valve cover on first day I bought.
Old January 17th, 2012, 10:42 PM   #103
Skooter_Built
Its not bad to replace them, 5 minutes of work. Actually I learned a trick that if for whatever reason its cold and your truck wont start, take a set of jumper cables and attach one to the positive battery terminal and another to the right main power lug on the relay, facing the engine its the lug closest to the drivers side. Your truck will start in seconds!
I change my oil every 6000 miles and use regular Rotella. If you are a member of Sams Club you can buy Rotella for cheap, usually 35 bucks for 3 gallons.
Old January 17th, 2012, 10:47 PM   #104
Mr. Beefy
BFT!
Mr. Beefy's Avatar
You know they make a big ass glow plug relay right? Muddypaws put one in his and it's been starting great since as far as I know. Drummond (brent) clued him in on it.
Old January 18th, 2012, 10:38 AM   #105
Skooter_Built
Yes but now that I'll get a free one when it goes bad why spend money on something else?
Old January 18th, 2012, 11:04 AM   #106
Mr. Beefy
BFT!
Mr. Beefy's Avatar
I dont know so maybe your truck starts every time...
Old January 18th, 2012, 12:06 PM   #107
MilwaukeeF350
Dan
I use screwdrive jump 2 posts on relay. been doing this for 1 month.
You should try 5W40 shell T6 synth. I saw about 1 mpg improve in coldest outside plus quieter.
Old August 10th, 2012, 09:18 AM   #108
Skooter_Built
Have a slight update to report, might help other Ferd turd oil burners. I replaced the factory tiny and leaking trans cooler with a huge 6.0 trans cooler awhile back. Since then the trans started running hotter then it ever has, hitting 200+ degrees with easy driving. I figured either the install on the new cooler was wrong, torque converter was failing or the whole trans was on the way out. I eventually started poking around and checking things out and nothing was wrong with the cooler install. Crap, this is looking expensive! Actually not, the fix was only $30 bucks.
What a discovered is that 4R100's and their older brother's have a bypass tube/valve on the return lines which in cold operation cycle the fluid through the trans first until proper temps are reached before going through the cooler system. Well mine failed so the fluid was only going through the trans nd never getting cooled. I ordered a sonnex bypass valve rebuild kit online, rebuilt and installed it and so far no overheating issues to report.
Old August 10th, 2012, 09:26 AM   #109
tom77cj5
tom77cj5's Avatar
They like to rust out too
Old August 10th, 2012, 10:03 AM   #110
Porter
Porter's Avatar
Default Hmmmmmmmm
this thing isn't parted out yet?
...oh wait......wrong white vehicle...
Dirty Minds Jeep Club
DMJC WEBSITE
Originally Posted by Twilight View Post
so yeah what Ross said...
Porter is offline   Reply With Quote
Old August 13th, 2012, 02:39 PM   #111
Skooter_Built
FAIL!!! Back to hot trans
The back of the trans pan is leaking and the back of the housing is wet. Everything aft of that is coated, WTF!!! I cant win with this Stupid Duty.
Old August 13th, 2012, 03:53 PM   #112
MilwaukeeF350
Dan
I rid of mine since it gotten money pit to keep on road.
I replaced with 99 F250 2wd 5.4L and 91 E350 diesel. No problem pull trailers that F350 did.
Old August 13th, 2012, 03:55 PM   #113
masterbeatty
masterbeatty's Avatar
delete the tube.
Old August 14th, 2012, 01:18 PM   #114
Skooter_Built
Originally Posted by masterbeatty View Post
delete the tube.
The tube doesn't seem to be the issue, everything behind it is wet. Its like the seal around thetrans output and tcase input is the problem. I checked the pan bolts and none were loose, still torqued to the setting i had them at.
Page generated in 1.29642 seconds with 65 queries
