F-250 Super Duty tow rig upgrades and maintance build - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 9th, 2011, 08:47 AM   #81
kickstand
circling the drain
kickstand's Avatar
Originally Posted by roger View Post
and what do you get mpg im only getting 12.5 in my 2003 7.3
you're either driving it like you stole it or you got mike hancho the highcenter king of superduties with bad fuel mileage type issues.
I pull anywhere from 15-22 empty, typically 18. 10 towing occasionally 14.
The pics you posted on FB of your truck look great roger, is it all stock?
Old December 9th, 2011, 09:30 AM   #82
mschaffer66
mschaffer66's Avatar
Is this thing sitting on jack stands next to the pale whore now as well?
Old December 9th, 2011, 09:38 AM   #83
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
mine started out like that...I changed the exhaust back pressure switch and it jumped to 15-18mpg
Old December 13th, 2011, 11:11 PM   #84
roger
roger's Avatar
Send a message via AIM to roger Send a message via Yahoo to roger
no chad it got bully dog and a staight pipe and atf bully doog cold intake
roger is offline   Reply With Quote
Old December 13th, 2011, 11:13 PM   #85
roger
roger's Avatar
chad the truck looks like it came off the show room floor no rust no where. Hancho i will have to try that thanks
Old December 14th, 2011, 08:13 AM   #86
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
My truck is still running strong, with the 20's and bigger tires I've lost some MPG, im usually 17 or less now but im still satisfied with the overall upgrades. Im collecting parts for the upcoming paint work. I still want to put a locker up front and a Detroit in the rear.
I'm the man in White.
Skooter_Built is online now   Reply With Quote
Old December 14th, 2011, 04:27 PM   #87
Strangler
Strangler's Avatar
Swap the guts out of the TJ axles.
Old December 14th, 2011, 07:08 PM   #88
roger
roger's Avatar
hancho i ran a scan on the truck today and it come up bad thanks for the heads up
Old December 14th, 2011, 07:17 PM   #89
Christmas Cookie
no problem...it helped mine out, but I still have an issue...chad and these other guys are still pulling better mpg's than me
Old December 14th, 2011, 10:16 PM   #90
roger
roger's Avatar
what yr is your truck
Old December 15th, 2011, 07:08 AM   #91
mschaffer66
Originally Posted by Skooter_Built View Post
]I still want to put a locker up front and a Detroit in the rear.
Why?
I get all of the other stuff you have done. But why do something like that? All that's going to do is give you the ability to put the truck in situations where you will fukc it up.
Leave the truck a DD and tow rig and put your efforts into the TJ. It sounded kinda like you were over the hump with the TJ...why not finish it off?
Old December 15th, 2011, 07:29 AM   #92
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Originally Posted by mschaffer66 View Post
Why?
The tu could be done in two or three weeks no problem!
H.o.r.e
Old December 15th, 2011, 08:52 AM   #93
Elvis13
How difficult was that unit bearing replacement? For some reason i remember people saying they are a pain.
Old December 15th, 2011, 10:04 AM   #94
Skooter_Built
Why?
Cause the fat bitch gets stuck on wet grass! Its so front heavy its a pain in the ass.
Ill see how much I can get done when chrysler is shut down.
Its actually quite easy, hardest part are getting some snap rings off and pulling the axle shaft out, Very straight forward and pretty simple
Old December 15th, 2011, 11:31 AM   #95
kickstand
circling the drain
kickstand's Avatar
then your tires suck.
Locking this truck front and rear is just stupid.
Old December 18th, 2011, 06:13 PM   #96
Christmas Cookie
2000? might be a 2001 I dont remember
Old December 18th, 2011, 07:23 PM   #97
joe_jeep
welfare wheeler
joe_jeep's Avatar
i thought diesels got better mpg than that?
Old December 19th, 2011, 10:57 AM   #98
kickstand
circling the drain
kickstand's Avatar
depends on if you are talking to an idiot or someone who is realistic in their expectations.
I've seen 21 mpg, but I very rarely get that lucky. 17-18 is average and more realistic.
Old January 17th, 2012, 09:09 AM   #99
Skooter_Built
Did some slight upgrades to my truck over the last few weeks. First was I put on some pocket style fender flares to keep off the road garbage off my truck. Second was I installed a MUCH larger 6.0 tranny cooler to replace my leaking tiny 7.3 trans cooler. It's a pretty straight forward swap, I had to take out my larger 6.0 inner cooler for the install so I could reposition it from when I put it in a few months ago. I also installed a new glow plug relay.
If you were ever interested in doing the larger 6.0 inner cooler/trans cooler upgraded, I'd suggest doing them at the same time, will save you alot more time in the long run.
Old January 17th, 2012, 06:02 PM   #100
MilwaukeeF350
Dan
What glow plug relay you bought?
For those people who got less mpg. Check fuel filter housing and gas tank to make sure it not leak diesel.
Page generated in 0.29874 seconds with 83 queries
