F-250 Super Duty tow rig upgrades and maintance build - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 9th, 2011, 12:38 PM   #61
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Got some work done on the truck this yesterday, installed new balljoints, draglink, tierod, unit bearings and the slotted and drilled rotors. I also dropped off my 20's at Belle Tire and they mounted the new 305/55/R20 GoodYear DuraTrac's. I pick them up Monday and will have an alignment done.
For those looking to replace their unit bearings go to your local autozone and buy these; http://www.autozone.com/autozone/par.../N-jhdglZ6o2ny
They are Timkin's with a 3 year warrenty for only $166 each.
And if need to rebuild your front end, this is what I went with. http://cgi.ebay.com/ebaymotors/XRF-U...item4cf625d463
This weeks activities will involve installing the 08 Mirrors and maybe the upfitter dash parts. Ill post pics later on.
I'm the man in White.
Old October 10th, 2011, 07:30 AM   #62
Skooter_Built
As promised pictures, nothing shocking or surprising.
Cleaned up 20's with old tires
Hover truck
Piece of shit 2 year old unit bearing that lost a wheel stud that then took out the ABS sensor.
All new steering parts
As for suspension and drivetrain upgrades to complete I still need to install new shocks all around, replace the rear hub seals as they are leaking, service the diffs with new synthetic fluid, front inner seal's, aluminum rear cover.
Im also thinking about installating a upgraded valve body and bigger trans pan when I get the fluid flushed and im debating on installing a lunchbox locker upfront.
Old October 10th, 2011, 12:44 PM   #63
kickstand
circling the drain
kickstand's Avatar
scoots, how much were all the front end parts?
hubs, tie rods, ball joints, etc.
I am thinking my truck could use a once over.
Old October 10th, 2011, 12:46 PM   #64
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Old October 10th, 2011, 01:12 PM   #65
kickstand
circling the drain
kickstand's Avatar
Originally Posted by Mr. Beefy View Post
well....in my defense, ummm hmmm....uhhhh......hey skoots start that cummins swap yet?
Old October 10th, 2011, 01:56 PM   #66
Skooter_Built
You're such a nagger! I will say im extremely happy I replaced everything all at the same time as it ensures no weaknesses as everything that was replaced needed to be.
Old October 10th, 2011, 07:32 PM   #67
Skooter_Built
Just got the truck back from belle tire. As of right now im stoked with the new duratrac's
Old October 11th, 2011, 06:55 AM   #68
kickstand
circling the drain
kickstand's Avatar
looks great skoots, I think I am gonna buy that kit sometime over the winter as well, replace it all at once and tighten everything up.
Old October 11th, 2011, 07:21 AM   #69
Skooter_Built
Last night I got bored and decided to install the 08-11 tow mirrors. Its a pretty straight forward install, they bolt right on after you chop off a plastic nub on the drivers side. The wiring is a mild pain in the ass, trying to track down what wire is the turn signal wire is messing me up currently. I haven't hooked up the heated mirror option yet, once I install the upfitter dash pieces ill wire in the heated mirrors.
If you tow, get these mirrors! Your field of view increases double of the original tow mirrors that I had. Plus they look that much better IMO. Tonight I have to finish installing the passenger side.
Cell comparison pics :
Old October 11th, 2011, 09:23 AM   #70
kickstand
circling the drain
kickstand's Avatar
if my truck wasn't all dentered up that mod would be on my list as well....did you start the cummins swap yet?
Old October 11th, 2011, 10:07 AM   #71
Looks good. I swapped the stock mirrors for the tow mirrors on my 09 F150 (the mirrors are basically the same thing), and love the difference. The panoramics at the bottom are great. zero blind spots, and you can look down and see your rear tires in the mirrors.
Anytime you need stuff like that, TASCA Ford sells stuff online cheap. I got my tow mirrors and trailer brake controller through them.
Old October 11th, 2011, 11:24 AM   #72
Skooter_Built
you fix your outboard yet?
Old October 12th, 2011, 09:36 AM   #73
kickstand
circling the drain
kickstand's Avatar
No, I was waiting for you to finish your cummins swap, palehores tj, and move out of your parents basement.
Old October 12th, 2011, 09:53 AM   #74
Skooter_Built
You can wish in one hand and shit in the other and see which fills up first.
I finished up the mirror install last night. Both mirrors are operational with the marker lights hooked up. Ill wire in the heated mirrors when I wire up the upfitter dash. The turn signals are a different story. I still cannot find the under dash wires so I might either hook them into the marker lights or run them to the headlight turn signals.
Old October 12th, 2011, 09:59 AM   #75
kickstand
circling the drain
kickstand's Avatar
Who said anything about wishing? I said I was waiting. Silly skooter. shitting in your hand is for odd cultures over seas.
What is this upfitter dash you speak of?
Not that I will every try to make my 11 year old truck into a 2008, but are you trying to shove a 2008 dash in there?
Speaking of, the 2008+ trucks make ours looke like they came out of the 70's on the interior side of things.
Old October 12th, 2011, 11:00 AM   #76
Skooter_Built
The upfitter dash is a new lower dash assembly, its been available on Superdutys since 05. It replaces the cup holders and cubbyhole area with a new panel and an electrical switch panel, which allows for easy wiring for lights or other electrical components. On 99-04 trucks slight modification to the dash and wiring are required, 05 and up trucks its a straight bolt in.
Here's what it looks like in our style of truck
Yes I realize our interiors match those of work trucks, im doing research on the possibility of swapping in a newer 05-07 dash.
Old October 12th, 2011, 11:52 AM   #77
kickstand
circling the drain
kickstand's Avatar
hmmm, I think I am good with my current dash....what I really want is more 12v plugins
Old October 13th, 2011, 03:43 PM   #78
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
upgheyer dash is dumb...I'll leave mine alone...but I do like those mirrors
Old December 8th, 2011, 10:32 PM   #79
roger
roger's Avatar
Send a message via AIM to roger Send a message via Yahoo to roger
hey skoot you think the old dash would work with the new switch panel useing the cubby hole
roger is offline   Reply With Quote
Old December 8th, 2011, 10:33 PM   #80
roger
roger's Avatar
and what do you get mpg im only getting 12.5 in my 2003 7.3
Page generated in 0.45229 seconds with 83 queries
