F-250 Super Duty tow rig upgrades and maintance build - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 31st, 2011, 02:01 PM   #1
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
Default F-250 Super Duty tow rig upgrades and maintance build
I've owned my 02 Super Duty since July 08 and have decided that this truck is too good to let go of, so im putting down the money and time I've been lacking on it to bring it back to show room new and give it a few upgrades at the same time :) plan's will include exterior body clean up and paint work, drive train work and interior improvements
*Current specs*
02 F-250 crew cab lariat short bed 7.3 auto 4x4 with 132k miles. Came fully loaded from the factory. I've installed a leveling kit up front (came with air bags in the rear), Tony Wildman 6 position chip, Afe stage 2 intake, 4" Turbo back exhaust, 05 conversion headlights and cut down grill, warn hubs, spray on bed liner and a goose neck hitch.
*Stage 1 work that's underway*
new drilled/slotted rotors front and rear with ceramic pads, xfr ball joints, tie rod and drag link, 4 new shocks (belsteins or ranchos), new 17" aluminum wheels with 315/70 Good year duratrac tires, 08 tow mirror with heat and lights, 05-07 front bumper with the Harley grill, pocket style fender flares, 05 lower dash w/ upfitter switches, 6.0 intercooler and trans cooler, all fluids/filters flushed and replaced then a full interior and exterior detail.
*stage 2*
Ship it off for paint and body work. By luck I have no major rust issues on the cab, bed or doors just surface rust. So I will have that repaired along with a few dents. I want nothing fancy, just other then to make it look factory again.
*stage 3*
This will happen come winter or spring but I will have the audio system improved with new speakers and a sub amp combo, new drivers seat bottom leather and a newer rear flip and tumble rear leather bench. Under the hood ill get an adrenaline hpop and regulated fuel setup for a little more power and some tranny valve body upgrades
In total should run a couple thousand for all this; minus paint, wheels & tires, whatnot... but its better it save my truck now then to have the payments of a newer truck.
My truck from last year, doesn't have the 20's installed right now
I'm the man in White.
Old August 31st, 2011, 02:29 PM   #2
joe_jeep
welfare wheeler
joe_jeep's Avatar
my 2002 is a v10 gasser. f250 super cab, short bed, lariat, 4x4.
its one of the best vehicles i have ever owned.
at 40k-4 tires (305/70/16 toyo open countrys)
at 60k-front pads and rotors
at 75k changed rear gear lube and friction modifier(it was chattering a little)
at 90k 4 nice used rims and 4 new kelly safari trex (285/75/16)
at 100k i did- ball joints (they had a little slop would have been fine for a while)
wheel bearings (the left side was making a little noise, right was fine. replaced both)
changed all the fluids, except rear axle and radiator.
at 110k did rear pads and rotors
new springs and 1" leveling kit going on soon.
my truck was way over gvw with the truck camper and jeep in tow.
it has performed very well. it hauled 17k without any issue.
it has never not started, or need a tow.
it was my first ford truck. got a sweet deal on it.
Old August 31st, 2011, 02:33 PM   #3
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Is this after you finish A jeep?
H.o.r.e
Old August 31st, 2011, 02:37 PM   #4
Skooter_Built
Haha ill have the Cj wrapped up tonight or tomorrow
Old August 31st, 2011, 02:46 PM   #5
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Haha do u still have that sanoma
H.o.r.e
Old August 31st, 2011, 02:54 PM   #6
Skooter_Built
Yep installing a new timing chain on it, started tearing it down last night.
Old August 31st, 2011, 03:21 PM   #7
Fidget56
Fidget56's Avatar
Take it to Hallas I thank he might be able to help you out with Trans and power.
Fidget56 is offline   Reply With Quote
Old August 31st, 2011, 03:27 PM   #8
kickstand
circling the drain
kickstand's Avatar
skooter I admire your big dreams, what happened to the 1,000 hp 24v conversion?
Old August 31st, 2011, 03:41 PM   #9
ajmorell
ajmorell's Avatar
I was curious about this also
Old August 31st, 2011, 03:44 PM   #10
Skooter_Built
I told you next year fall or winter its getting the cummins and I only want 500 HP , right now I just want to do all the necessary maintenance to make it a safe and reliable tow pig and dd.
This all sparked Monday when I realized how bald my tired were. No use to by new tires if the steering is out of allignment and the brakes are shot, which all are. Some of the parts intercooler, trans cooler, dash parts I've had for a few years now and never installed.
Old August 31st, 2011, 03:46 PM   #11
Mr. Beefy
BFT!
Mr. Beefy's Avatar
So your gonna do all the motor work then put a cummins in? Weird.
I do say you have a good lookin ferd tho
Old August 31st, 2011, 04:14 PM   #12
Skooter_Built
The motor work isn't what your expecting as its not for performance but reliability. The adrenaline high pressure oil pump and a regulated fuel setup will help balance out the oil and fuel to the injectors ensuring they pump at a balanced rate. The 6.0 innercooler helps lower egt. All that might get me 25 extra HP then I have now but keeps the engine happier and running reliable.
Plus trying to pump more power into my 7.3 only can make it weaker as powder metal cast rods get dangerious over 400 hp. I don't wanna install forged rods or do more turbo upgrades then a wicked turbo wheel.
Old September 1st, 2011, 07:54 AM   #13
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Is it done lol
H.o.r.e
Old September 1st, 2011, 08:39 AM   #14
Skooter_Built
Is it done lol
Other then buying some new u joints and tightening some bolts yes
So far with the F250 the brakes are on there way from Chicago, steering from Ontario, 08 mirrors from Brighton Mi. Im waiting to get the total for the 05 bumper from my buddy that works for a Ford body shop. Im going to order the 6.0 conversion inner cooler boots today along with some other parts.
Old September 1st, 2011, 08:42 AM   #15
kickstand
circling the drain
kickstand's Avatar
how's the palehorse?
Old September 1st, 2011, 08:57 AM   #16
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Cool so u built a mount for the205 too?
H.o.r.e
Old September 1st, 2011, 08:58 AM   #17
Skooter_Built
Doing good just like your boat
Been growing cobb webs for the last month or so. My add and short attention span has kicked in so time to fix my only running DD before it strands me
As for the 205 support im still deciding where the support is gonna go Scott. Either off the pto cover or the rear output, I ran outta light last night
Old September 1st, 2011, 01:43 PM   #18
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Whoops - I can see I'm too late...
Never use drilled rotors on anything you expect to stop safely (for long).
@clarkstoncracker
Old September 1st, 2011, 02:23 PM   #19
What are ya doing with your old intercooler stuff ?
Old September 1st, 2011, 03:09 PM   #20
Skooter_Built
That bad huh, its worth a try I guess. Compaired to 4 stock replacement rotors and pads I only spent 35 bucks more.
Will be for sale soon.
Page generated in 0.31871 seconds with 83 queries
