gmc jimmy - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 30th, 2011, 04:19 PM   #1
kasespinney
kasespinney's Avatar
Default gmc jimmy
we reaplaced the engine in our jimmy and cant get the fireing down cant figure out the distributer we took it apart and dont know how to realighn it up we found tdc and lined up the 3 paint marks on it and wont fire we didnt put the marks on it but still dont know what to do please help
kasespinney is offline   Reply With Quote
Old August 30th, 2011, 04:37 PM   #2
Disturban
Disturban's Avatar
Who pulled and marked the distributor? If someone else did then you should not have turned the motor to tdc, instead you should have just dropped the dizzy back in and lined up the marks. Now the marks are useless, just rotate the motor to tdc and align the mark on the harmonic balancer and point the rotor to #1 cylinder, this will get you in the ballpark enough to start it, if it still wont start you have other issues, forgot to hook up a wire or something.
What year is this? If it is a 1998 or newer after you get it running you will need to take it to a shop or find someone with a TechII or SnapON solus and have a crankshaft relearn procedure performed on it. It basically calibrates the computer with the crankshaft position sensor. When ever you change the crankshaft position sensor, computer or in your case the whole motor in a 1998 or newer GM you need to preform this procedure, your CEL may or may not come on until you do but even if it does not set a CEL you should still do it!
Old August 30th, 2011, 04:48 PM   #3
GREASYHANDS
GREASYHANDS's Avatar
^^^ not entirely true. You do need to have the scanner to set the timing. A crankshaft relearn is also good to do but not needed on a motor swap.
Align the mark on the balancer to the front cover timing mark. If the engine is a vortec the distributor will have a mark on it for 6 or 8 clys. point the rotor at the #6 on the dizzy. This will place the rotor facing the pass side of the engine. tighten every thing up and try that, if it wont fire turn it 180 deg and try again.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old August 30th, 2011, 07:55 PM   #4
kasespinney
its a 97 and its a new block and we didnt mark it and on the distributer do u align it with the #1 where the wire comes out or where the prong is at
Old August 30th, 2011, 08:10 PM   #5
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
Line it up with the prong under the cap going to #1 plug wire.
Old August 30th, 2011, 08:15 PM   #6
GREASYHANDS
^^^ this.
The number 6 will be right under the rotor on the distributor case. Once you line both up it should fire .
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old August 30th, 2011, 09:02 PM   #7
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i'm thinking you didn't plug a sensor in. crank sensor could get missed easily due to it's location.
Old August 31st, 2011, 03:56 AM   #8
Disturban
Disturban's Avatar
This is what I am thinking also, even if the timing was way way off you would at least get a sputter, backfire, ect. Did you check to see if you are getting spark and fuel?
Page generated in 0.26608 seconds with 47 queries
