Panhard Kits and Components From Ruffstuff! - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old August 30th, 2011, 12:44 PM   #1
Gravel Maker
Steel Hauler
Gravel Maker's Avatar
Arrow Panhard Kits and Components From Ruffstuff!
These are pretty straightforward and simple, all it takes is a quick look and you understand what you need to do and more importantly, what you need to order!
We start you with 48" of 1.5" x .25" wall DOM tubing, then we make you choose between an axle Centered or Offset Bracket, and finally you decide if it will mount on the frame Inside or Outside. The Brackets give you 5 choices of mounting height.
It comes with a set of our 7/8" x 3/4" 4130 Heat & Cryo treated Heims with Stainless Misalignment and Hex Head weld bungs. The Hex Head bungs give you very fine adjustment easily. We also include the Grade 8 bolts in the correct length so you don't have to spend your day searching for them.
Here is a pic with both bracket choices so you get an idea of how it goes together...
http://www.ruffstuffspecialties.com/catalog/PANKIT.html
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Your Fabrication Parts Source
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old September 7th, 2011, 12:36 PM   #2
Gravel Maker
Steel Hauler
This kit has the options to make it easy...
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old September 25th, 2011, 03:37 PM   #3
Gravel Maker
Steel Hauler
Thanks for using these, this month 6 went to Michigan. Lots of building going on!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old October 5th, 2011, 12:25 PM   #4
Gravel Maker
Steel Hauler
The building season is here, time to decide just what you are going to do this winter ;)
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old October 26th, 2011, 03:21 PM   #5
Gravel Maker
Steel Hauler
I say link it up ;)
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old November 4th, 2011, 03:37 PM   #6
Gravel Maker
Steel Hauler
Just back from SEMA, thanks to Ty for keeping us updated while Garett and I were gone. It was a very busy week for only 2 of us to deal with but we will be bringing some very interesting and new items to market! Lots of great ideas ;)
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old November 11th, 2011, 05:41 PM   #7
Gravel Maker
Steel Hauler
This week has been one of our busiest weeks on record, thankyou all!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old December 2nd, 2011, 01:54 PM   #8
Gravel Maker
Steel Hauler
Keep the orders coming!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 4th, 2012, 03:03 PM   #9
Gravel Maker
Steel Hauler
Time to get that axle tracking striaght again?
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 17th, 2012, 01:30 PM   #10
Gravel Maker
Steel Hauler
Any lift at all and you will need to adjust your Panhard, is yours even adjustable?
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 31st, 2012, 08:51 PM   #11
Gravel Maker
Steel Hauler
These are an industry staple!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old February 17th, 2012, 06:06 PM   #12
Gravel Maker
Steel Hauler
If you need one these are the best!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old February 29th, 2012, 08:09 PM   #13
Gravel Maker
Steel Hauler
If its time to tie it all together its time for one of these!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old March 7th, 2012, 10:57 PM   #14
Gravel Maker
Steel Hauler
I should mention that some of you are running a panhard with leaf springs. It seems to have started with Toyotas but I see it spreading.
First off they are diametrically opposed in what they do and using both will cause undue wear & stress on both and eventually break one or both.
Secondly, the reason you are doing it is to track better on the road but if you go offroad you take it off. At least you are doing it right offroad. If you are not tracking well fix the issue, don't add something that will only destroy something else.
The issue could be one of several things. You could simply have worn out bushings in your springs. You could have sloppy springs. This could be as easy as no clamps, broken center pin, simply worn from rubbing against each other, or maybe your tires are simply too big for your suspension to handle on the road(too much balloon).
First fix the issue, these are for link suspensions, not a bad spring setup.
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old March 15th, 2012, 03:19 PM   #15
Gravel Maker
Steel Hauler
Time to fix the issues!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old May 3rd, 2012, 01:36 PM   #16
Gravel Maker
Steel Hauler
Lots of ways to get the panhard wrong, think about doing it right!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old May 18th, 2012, 02:30 PM   #17
Gravel Maker
Steel Hauler
Fix that crabwalking!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old May 29th, 2012, 07:18 PM   #18
Gravel Maker
Steel Hauler
A simple way to tell if you have binding issues with your Panhard is:
When your rig is sitting there, not moving, and you turn the wheel and the drivers side lifts 1/2" to 2" you are binding on the panhard.
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old June 27th, 2012, 04:39 PM   #19
Gravel Maker
Steel Hauler
Track straight, don't crabwalk!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old July 24th, 2012, 05:23 PM   #20
Gravel Maker
Steel Hauler
Get it right this time!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Thread Tools
Page generated in 0.31683 seconds with 83 queries
