dana 60 question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 20th, 2006, 09:41 PM   #1
junk90xj
ALLPRO AUTO
junk90xj's Avatar
Default dana 60 question
ive got a dana 60 semi floater from a 1 ton dodge cargo van. the width is a few inches off from the 35 in my xj, which i can make up with backspacing. so is this worth putting gears and lockers into to run 37's? i dont know spline count because its still in the van. my other option is one of my two 9inch's.
http://www.apalansing.com/
Old September 20th, 2006, 09:45 PM   #2
boggin-machine
boggin-machine's Avatar
dana 60 rears aint worth a hole lot. i got a buddy with one that has 410s thats forsale if interested pm me. i bet hed take 200
Old September 20th, 2006, 09:49 PM   #3
junk90xj
ALLPRO AUTO
junk90xj's Avatar
iTrader: (-1)..............no thanks
ill be building my own but cant make up my mind which one. 60 will be easier i think. just not sure if the semi floaters were any good.
Old September 20th, 2006, 10:53 PM   #4
PavementPounder
PavementPounder's Avatar
Pull a shaft and check the splines. The 60-2's were 35. Its worth taking a look...
Old September 21st, 2006, 06:42 AM   #5
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
What are you going to run for a front axle? Or do you plan on carrying two spare tires?
Old September 21st, 2006, 10:49 AM   #6
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
You could always order new shafts that are 5x4.5 and are 35 spline since you are gonna lock it. Alot of jeep owners run the semi-float so thay can run a 5 lug axle easier. My .02
Old September 21st, 2006, 10:58 AM   #7
junk90xj
ALLPRO AUTO
junk90xj's Avatar
either a 44 or 9 inch with 60 outers
Old October 5th, 2006, 10:34 PM   #8
95geo
newbie
95geo's Avatar
if your going to be spending the money go with the 9" center sections and run 35 spline stuff in them, just as strong as a 60 but weighs quite a bit less. dont run a 44 senter section with 60 outers. youll kick yourself in the ass when your $3000 axle just shit a ring and pinion.... just do a 60 and be done with it.
on the trail it seems like a front 60 doesnt really get hung up all that much because you can steer around the stuff, the rear is always the one to get hung up. 60 front and a shaved 9" rear both 35 spline
Page generated in 0.17916 seconds with 47 queries
