Getting the most out of stock Power Steering - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 29th, 2011, 11:25 PM   #1
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
Default Getting the most out of stock Power Steering
What does it take to get the most out of your stock power steering pump and box?
Iím trying to turn 35s at 10lbs and needless to say Iím having troubles, and the mini spool isnít helping.
The only article I have found is this
turn up the pressure on power steering pump. - Pirate4x4.Com Bulletin Board
Iím sure some of you have some secrets, you're willing to share
Old August 31st, 2011, 09:27 AM   #2
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
Really no one has tried a overdrive pulley, or found a way to make more pressure at lower rpm?
Old August 31st, 2011, 09:33 AM   #3
Sandals
Fucking Zen as Shit
Sandals's Avatar
I have a saginaw style pump in my YJ, and i did a mod that modified the spring and drilled out the fitting. It seems to have helped a little, but i really haven't driven it that much to know if it really did a lot.
http://westtexasoffroad.homestead.co...rsteering.html
Old August 31st, 2011, 09:49 AM   #4
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
^^^That’s a nice write up
Anyone done this and have enough seat time to determine if it was worth it?
Old August 31st, 2011, 09:52 AM   #5
Sandals
Fucking Zen as Shit
Sandals's Avatar
Originally Posted by wadey View Post
^^^Thatís a nice write up
It only takes like an hour to do and a bottle of PS fluid go for it!.
The guys who are recommending it build full hydro, and hydro assist set-ups, and they feel it's worth it.
Old August 31st, 2011, 09:58 AM   #6
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
Alright ill give it a shot, just hope I don’t get too carried away and blow out my seals.
Old August 31st, 2011, 10:01 AM   #7
Sandals
Fucking Zen as Shit
Sandals's Avatar
Alright ill give it a shot, just hope I donít get too carried away and blow out my seals.
LOL just be selective on the size of bit you use.
I found a bit the same diameter and went up slightly less than 1/8" they recommend.
I did this mod 6 years ago, and haven't any issues.
Old August 31st, 2011, 10:07 AM   #8
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
Good to hear, Iíll give it a try and report back with my findings.
Old August 31st, 2011, 10:08 AM   #9
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Very cool. I may do this as well. Thanks Sandals.
RIP FULLSIZE4LIFE
Old September 3rd, 2011, 05:26 PM   #10
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
I just tried this mod, and now I don’t have any power steering. It worked really well at first and then it just quit. I also added a cooler while doing this, it shouldn't affect anything. Also I don’t see any leaks.
Any Ideas?
Thanks
Old September 3rd, 2011, 08:42 PM   #11
Sandals
Fucking Zen as Shit
Sandals's Avatar
I just tried this mod, and now I donít have any power steering. It worked really well at first and then it just quit. I also added a cooler while doing this, it shouldn't affect anything. Also I donít see any leaks.
Any Ideas?
Thanks
Either the relief valve got fuxored somehow, or something is blocking fluid flow.
Old September 3rd, 2011, 09:05 PM   #12
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
How far did you shave the limiting stud, thats the only thing I can think of
Old September 3rd, 2011, 09:25 PM   #13
Sandals
Fucking Zen as Shit
Sandals's Avatar
I just removed the shim that was in there and put it back together
Old September 3rd, 2011, 09:27 PM   #14
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
Mine had no shim and i added a thin washer instead
Old September 4th, 2011, 01:13 AM   #15
blownexploder94
Todd
blownexploder94's Avatar
try a saginaw pump, higher output (flow/pressure) good write up here
http://www.pirate4x4.com/tech/billav...ng/index2.html
Old September 4th, 2011, 06:07 PM   #16
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
Well I found out my power steering pump took a shit. Not sure if it was from this mod or something else.
But Ill give it another try once I get my new pump on.
Old September 4th, 2011, 11:50 PM   #17
in2deep
Hole tester
well mileage and 35" tall tires plus spool most likely did it but shim may have helped
did sliders fall off yet buy the way
Old September 5th, 2011, 02:14 PM   #18
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
haha Iím sure it didn't help any, but it sheared the shaft that the pulley rides on in two. It was a clean break, not sure if I blocked off all of the flow and that caused extra pressure on the on the pump, or what happened.
And the sliders havenít fallen off yet Their still not painted tho : ( the weather just hasn't been good enough. But Iíll be sure to let you know how they do at R&V in 2 weeks. Thanks again for the help
Old September 5th, 2011, 06:27 PM   #19
joe_jeep
welfare wheeler
joe_jeep's Avatar
my pump has the west texas mod. it works. if you sheared the shaft it already had issues. im a full hydro, dont know if that matters. i can turn 42's with a detroit with my pinky finger.
Old September 5th, 2011, 07:24 PM   #20
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
Yeah Iím sure mileage had something to do with it, but for it to happen right after I did this seems odd. It sheared within one minute after the mod. Then the pulley slid out and knocked the belt off while I was driving. I guess Iím just unlucky
Page generated in 0.33566 seconds with 84 queries
