1976 M35a2 Bobbed Dump 4x4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 29th, 2011, 08:26 PM   #1
ArmyTruckGuy
ArmyTruckGuy's Avatar
Default 1976 M35a2 Bobbed Dump 4x4
1976 AM General M35a2
I have owned this truck for seven years and it by far is my favor truck I own. However it does not fit in the family plan so it needs to go to a good home. Last year I “bobbed” (removed one rear axle) the truck and converted it to a dump bed. The truck went through a six month rebuild from the ground up, including an LDS engine swap. For those of you who don’t know the m35a2 come with a LDT-465-1c, which is rated @ 170 HP and 330 ft lbs torque. While the LDS-465-1A is rated @205 HP and 440 ft lbs of torque. This LDS came out of a m543a2 wrecker with only 9,800 miles on it. The engine runs great and has lots of power. Listed below are all the things that have been done to the truck.
• All new wheel bearings and seals (excluding front axle boots)
• Master cylinder, wheel cylinders, and air pack have been rebuilt or replace
• Remote master cylinder reservoir installed
• “Brake Lock” installed (holds all four brakes, great for winching or parking on steep hills)
• Gauges all work. New Tachograph installed. New Stewart Werner oil pressure gauge. Has boost and pyrometer gauges (pyrometer needs new sender)
• Has the rare dual out putt PTO. Front out putt controls the winch 2 speed forward, neutral, reverse. Rear out putt goes to hydraulic pump for bed.
• Exterior of the truck has been completely cleaned and painted
• All lights work Brand new rear harness. Installed running lights, rear work lights and spot light.
• 24 volt to 12 volt inverter installed runs the cb radio can also be used for other things like radio or cigarette outlet
• 395 85r 20 Michelin xml radial tire on M135 rims installed with New radial tubes and flaps.
• Has Tool box/ spare tire rack behind cab of a m818 5 ton tractor
• 15 gpm hydraulic pump, scissor style dump hoist, 2 spool valve bank with auxiliary valve.
• Lds engine swap
• Air compressor rebuilt
• Generator was rebuilt
• New rear main seal
Other features includes, Five speed overdrive Transmission, 2 speed hi-lo transfer case, Cab Heater, Hard top shell with rear sliding window, 12,000lb pto winch, dump box, cb radio, Driver and Passenger spring ride seats, Batterys are only 2 years old.
Sale price is $10,000 FIRM includes Truck, M105 Trailer< and whatever spare parts I have laying around.
Truck is sold as with NO Warranty expressed.
Please contact me for any Questions
Josh 231-330-3687
josh_lacombe@hotmail.com
Name:	DSC_0214 (Medium).jpg
ID:	82867   Click image for larger version
Name:	DSC_0217 (Medium).JPG
ID:	82868   Click image for larger version
Name:	DSC_0221 (Medium).jpg
ID:	82869   Click image for larger version
Name:	DSC_0226 (Medium).jpg
ID:	82870   Click image for larger version
Name:	DSC_0227 (Medium).jpg
Name:	DSC_0241 (Medium).jpg
ArmyTruckGuy is offline   Reply With Quote
Old August 29th, 2011, 08:39 PM   #2
trogdor48430
trogdor48430's Avatar
streetable?
trogdor48430 is offline   Reply With Quote
Old August 29th, 2011, 08:49 PM   #3
Jeep ZJ
Jeep ZJ's Avatar
this thing is fawkin sweet! GLWS!!!
Old August 29th, 2011, 08:54 PM   #4
ArmyTruckGuy
Yes has clear michigan title. drives nicely down the road. i have drove this truck to wisconsin and all over the stat of michigan without any troubles. regularly haul my skidsteer with it that ways 7000lbs
Old August 29th, 2011, 08:59 PM   #5
capone
capone's Avatar
Originally Posted by jeep zj View Post
this thing is fawkin sweet! Glws!!!
x2
capone is offline   Reply With Quote
Old August 30th, 2011, 04:20 PM   #6
ArmyTruckGuy
Forgot to add Truck comes with Brand new vinyl cargo cover with bows and sire racks (racks need new wood)
Old August 30th, 2011, 05:32 PM   #7
MayhemInc
I hate people
MayhemInc's Avatar
Forgive my ignorance but is the replacement engine the mutli fuel i keep hearing about? ...and the ridiculous question, is it as economical as a dump truck fuel wise or is it somewhat conservative
MayhemInc is offline   Reply With Quote
Old August 30th, 2011, 06:20 PM   #8
ArmyTruckGuy
yes its a multifuel. gets around 9-12mpg
Old August 31st, 2011, 09:18 AM   #9
jdustu
I weld
jdustu's Avatar
This is wicked. May have to give you a call if my bike sells. Although I'm not sure I'd have anywhere to park it!
Nice work, looks great.
jdustu is offline   Reply With Quote
Old August 31st, 2011, 09:19 AM   #10
MayhemInc
I hate people
MayhemInc's Avatar
what a harley bobber? Least it'd fit in the garage lol
Old September 1st, 2011, 04:21 PM   #11
ArmyTruckGuy
bump
Old September 3rd, 2011, 01:53 PM   #12
ArmyTruckGuy
Btt
Old September 5th, 2011, 08:00 PM   #13
ArmyTruckGuy
Btt
Old September 5th, 2011, 08:11 PM   #14
muddinman56
blood,sweat and beers
muddinman56's Avatar
i want this so bad but sadly dont have the cash bad ass truck man
Old September 9th, 2011, 09:27 PM   #15
ArmyTruckGuy
Btt bad ass tow/ camper rig 24,000lbs pto winch w/snatch block. on board air!!! I tow my m37 to drummond every year with it. took it to copemish last year and camped in the back!!
Old September 13th, 2011, 08:02 PM   #16
ArmyTruckGuy
Sold!!!!!
Page generated in 0.44897 seconds with 72 queries
