Another slightly more than mild XJ build - Page 19 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 7th, 2013, 11:58 AM   #361
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Originally Posted by kmanxj5011 View Post
Looks good!
Thanks!
RDK_YJ88 is online now   Reply With Quote
Old June 11th, 2013, 06:52 PM   #362
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Did a little more work to the Jeep. Most of that work was damage So she flies great, but the landing, not so much.
So the lack of frame mounted bump stops and the leverage designed into the cross tube caused the failure when the Jeep bottomed out. Luckily the hood didn't unlatch, so the oil pan was saved.
Plan of action to fix it was to redesign the cross tube with mounts that are centered under it, rather than behind it, and add some gussets. I decided to build this out of 3/16" plate and square tube, just to give it a different look.
Probably won't run a hood for a little while. Also picked up a new muffler and some mandrel bends to build a new exhaust.
One day I'll get around to build the exhaust.
Old June 12th, 2013, 04:35 AM   #363
John D
John D's Avatar
Any pics or video of the jump?
Old June 12th, 2013, 05:36 AM   #364
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Old June 12th, 2013, 05:40 AM   #365
curbdog17
Mini Van
curbdog17's Avatar
Originally Posted by RDK_YJ88 View Post
http://i859.photobucket.com/albums/a...ps31973eec.mp4
Old June 12th, 2013, 05:50 AM   #366
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Thanks. Trying to do this on my phone.
Not the biggest jump ever, but it's not the first jump either. I think it may have been weakened from previous dunes trips.
Old June 12th, 2013, 06:23 AM   #367
TOPTRUK
Never Ending....
TOPTRUK's Avatar
Looks good! Is this removeable if the 4.0L needs to come out?
TOPTRUK is offline   Reply With Quote
Old June 12th, 2013, 06:49 AM   #368
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
With a sawzall, yes The two bolt flanges on the other tube started pulling apart, so I decided to make this one solid.
Old June 12th, 2013, 10:45 AM   #369
TOPTRUK
Never Ending....
TOPTRUK's Avatar
As long as you don't beat the 4.0L like your brother I think you will be fine lol
Old June 12th, 2013, 03:33 PM   #370
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Old June 13th, 2013, 05:54 PM   #371
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
*2007 Rubicon
*2014 Duty
Old August 12th, 2013, 04:55 PM   #372
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Update: Alternator seized up from sitting outside without a hood.
Waiting to close on my new house, with a bigger garage before any real updates happen.
Old August 12th, 2013, 09:25 PM   #373
OnlyInMyXJ22
No Money = No Fun
*2007 Rubicon
*2014 Duty
Old August 14th, 2013, 07:27 AM   #374
TOPTRUK
Never Ending....
TOPTRUK's Avatar
You still want that other hood I have?
Old August 14th, 2013, 02:44 PM   #375
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
I might! What do you want for it?
Old August 15th, 2013, 06:23 AM   #376
TOPTRUK
Never Ending....
TOPTRUK's Avatar
12 pk of bud light and call it good? Was just going to give it to you butvj
Old August 15th, 2013, 06:24 AM   #377
TOPTRUK
Never Ending....
TOPTRUK's Avatar
Damn phone... But now that you mention it... Lol
Old August 28th, 2013, 10:09 PM   #378
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Little update. I ordered up a Dynomax 2.5" mandrel bent tail pipe. I was hoping it would get rid of the drone in the cabin. Also fixed the leak at the manifold.
Here's the Dynomax tailpipe I got:
http://www.summitracing.com/parts/wl...model/cherokee
It stuck out and down pretty far. The oval shaped tip would get caught on everything when backing up, so i trimmed it back and angled it away from the fuel tank.
Here's a quick video of the exhaust. Sounds a little deeper in person. I'm quite pleased with the way it turned out, and I believe the drone is much more bearable.
http://s859.photobucket.com/user/ram...tml?sort=3&o=1
Old August 30th, 2013, 08:43 PM   #379
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Well I got sick of the damn side panels being all rusty. So I fixed them...
Before:
After:
Still have some bolts to add, broke the tap though. Jeep probably lost close to 50lbs by losing the steel.
Old September 1st, 2013, 08:39 PM   #380
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Getting a little more work done. Started on the rear shocks finally. With the stock gas tank, and new tailpipe, I was pretty limited on space underneath. So I went through the fenderwell and tied into the cage.
Stretched it out to check for clearances, it just barely clears the tire. The tire might rub it slightly, but not enough to worry about.
Page generated in 0.31107 seconds with 84 queries
