Another slightly more than mild XJ build - Page 18 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 1st, 2013, 07:28 PM   #341
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Originally Posted by Asher View Post
I like the doors. On the tube where the back of the rear passenger door terminates what does the tube tie into? just wondering if you tied it into the interior cage supports or not.
Thanks!. No, it's not tied into the interior cage there.
Old March 2nd, 2013, 10:30 AM   #342
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Cutting out the Drivers side skin.
For the long straight cuts I used a metal disc on my 7" circular saw. This worked very well on the thin sheet metal. For that smaller rounded cuts, I used my 4.5" grinder with a cut off wheel.
Old March 2nd, 2013, 03:56 PM   #343
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
All done!
Old March 2nd, 2013, 04:30 PM   #344
John D
John D's Avatar
Is it low in the back or just an illusion?
You're right, you do need to open the rear wheel wells
Old March 2nd, 2013, 05:24 PM   #345
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
It's low in the back. About an inch lower. All the tires have different pressures too, from crap in the beads.
Old March 5th, 2013, 08:18 PM   #346
snocross2xtremes
snocross2xtremes's Avatar
lets go wheelin
snocross2xtremes is online now   Reply With Quote
Old March 5th, 2013, 08:25 PM   #347
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Yes
H.o.r.e
Old March 5th, 2013, 08:42 PM   #348
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Jeeps ready!
Old March 5th, 2013, 10:42 PM   #349
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Originally Posted by RDK_YJ88 View Post
Jeeps ready!
x2!
*2007 Rubicon
*2014 Duty
Old March 6th, 2013, 06:10 AM   #350
TOPTRUK
Never Ending....
TOPTRUK's Avatar
Originally Posted by OnlyInMyXJ22 View Post
x2!
X3. Bundy?
TOPTRUK is offline   Reply With Quote
Old March 6th, 2013, 03:31 PM   #351
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Originally Posted by TOPTRUK View Post
X3. Bundy?
That's what I was thinking!
Old March 6th, 2013, 04:06 PM   #352
bbaXJ
Yooper In Training
bbaXJ's Avatar
Jeeps ready!
Better go wheeling soon, I give it 3 days till it's dismantled for some other mod!
Old March 6th, 2013, 10:09 PM   #353
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
That's what I said!
Old April 6th, 2013, 06:04 PM   #354
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Update. Picked up a set of the JCR rear corner guards/ tail light boxes. These things are top notch. Very easy to install and fit great. Wiring the lights was stupid easy with the factory light sockets labeling the wires. I probably could have built these, but for the price it wasn't worth the hassle. I was also able to save some money on the LED lights by sourcing them locally.
Also built a new mirror for the Drivers side. Trying to make it a little more street legal for cruising around town this summer. Easily removable for trail rides.
Also put on a new radiator cap and fixed a broken wire for the fan. Ready for the trails now.
Old April 6th, 2013, 07:09 PM   #355
John D
John D's Avatar
Nice! I have a set of them also I will be putting on this week too. They are really well built. I need to match the wheel opening to mine before I can install. Where did you get the lights And do you have the part numbers to share?
Old April 6th, 2013, 08:08 PM   #356
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
I just picked them up at O'rielly's, but I'm sure autozone has something similar too. I'll check for the part numbers. I used smaller lights on the sides, so I had to fill in the hole and redrill a 3/4" hole.
Old April 6th, 2013, 09:05 PM   #357
OnlyInMyXJ22
No Money = No Fun
*2007 Rubicon
*2014 Duty
Old April 7th, 2013, 11:25 AM   #358
kmanxj5011
kmanxj5011's Avatar
Looks good!
kmanxj5011 is offline   Reply With Quote
Old April 7th, 2013, 11:56 AM   #359
John D
John D's Avatar
I found what I needed on eBay. Did you need a different flasher or did the Jeep flasher work okay?
Old April 7th, 2013, 11:58 AM   #360
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
It works but it flashes quickly. For the rare occasions ill drive it on the road, it will be fine. If there's a cheap easy fix for it, let me know, I'll fix it.
Page generated in 0.30322 seconds with 84 queries
