Another slightly more than mild XJ build - Page 10 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 1st, 2012, 09:26 PM   #181
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Nope, built those myself. Same design though.
Old December 1st, 2012, 09:38 PM   #182
snocross2xtremes
snocross2xtremes's Avatar
is it done yet?
Old December 2nd, 2012, 10:22 AM   #183
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
I hate rust....
Old December 2nd, 2012, 01:37 PM   #184
MiNi Beast
MiNi Beast's Avatar
Good cutting brakes flintstone style.
Old December 4th, 2012, 08:28 PM   #185
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Finally making some progress.
Finished up the floor, splashed some rustoleum brush on paint. Dirty already.
Hours after starting, the doors decided to finally come off. Man its rusty.
Yep, still rusty.
Started to cut it out. I cut all the way up to the sill, which will require the doors to be trimmed.
Drilled holes on the top side for more welding surface.
Same for the back door.
Old December 4th, 2012, 09:33 PM   #186
MiNi Beast
MiNi Beast's Avatar
So boat sides out of the question then or what? Chop, cut, and wheel, repeat!
Old December 4th, 2012, 10:19 PM   #187
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
I thought about it, but I didn't think they would look good on a Jeep that's only running 33's. I'll gain some clearance with the ones I'm building though.
Old December 5th, 2012, 07:23 PM   #188
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Possible new rocker/slider design. Would be made out of 3/16" plate if I decide to go this way, because I have almost a whole 4x8 sheet of it already.
Old December 5th, 2012, 07:32 PM   #189
snocross2xtremes
i like that better!
Old December 5th, 2012, 07:33 PM   #190
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Bring the Plasma cutter over!
Old December 5th, 2012, 09:21 PM   #191
John D
John D's Avatar
I like the idea/look, but how will you tie it in? If you did it like the pic the leverage from whatever obstacle would push it up easily. I think a few legs tied back to the frame would be necessary.
Old December 5th, 2012, 10:18 PM   #192
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
That's what I have been looking into. It will need "Fish bone" pieces inside the rocker to support the bottom. These pieces would give it the characteristics similar to box tube. Once I build the Hybrid cage off of it, it would get supports that go from the "frame" to the slider, and support the B-pillar tube of the cage in the middle. I think it is supportable though.
Old December 6th, 2012, 11:40 AM   #193
OnlyInMyXJ22
No Money = No Fun
OnlyInMyXJ22's Avatar
Originally Posted by snocross2xtremes View Post
i like that better!
x2
*2007 Rubicon
*2006 Duramax
*2005 CRD
Old December 8th, 2012, 08:54 PM   #194
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Alright here's my progress on the new rockers.
After taking measurements from the small sheet metal piece, I transferred them to the 3/16 plate.
Next, I marked the slots I wanted to cut out. First i drilled a small hole in the start and end of each line. The white lines will be cut.
Once those were cut using the plasma cutter, I started the bending process. I used the small sheet metal piece as a guide.
Once I finally got it all bent, I added some ribs inside.
Still need to go and weld up and smooth out the seems I cut, and make "caps" for the ends. The ends will be tapered to follow the wheel arches.
Thoughts, comments, concerns?
Old December 9th, 2012, 03:18 PM   #195
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Progress. Lots of welding left to do. Plus the driverside.
Old December 9th, 2012, 05:49 PM   #196
OnlyInMyXJ22
No Money = No Fun
Looks good!
*2007 Rubicon
*2006 Duramax
*2005 CRD
Old December 9th, 2012, 07:55 PM   #197
1997XJ
1997XJ's Avatar
Liking the sliders. Are you going to weld it along the underside too?
1997XJ is offline   Reply With Quote
Old December 9th, 2012, 08:08 PM   #198
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Yes, I left 1" of the pinch weld seam that I folded over and welded the length of the slider.
Completely welded up now. Time to move onto the drivers side.
Old December 9th, 2012, 09:14 PM   #199
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Nice work
Old December 9th, 2012, 10:06 PM   #200
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Thanks!
Page generated in 1.18497 seconds with 84 queries
