360 engine ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 20th, 2006, 05:29 PM   #1
junk90xj
ALLPRO AUTO
junk90xj's Avatar
Default 360 engine ?
question is will a 1987 360 short block work in a 1994 zj with the zj heads,intake,ect. i just dont know if the bellhousing bolt patterns are the same and the mounting of the heads and intake. also what about the motor mounts?
any info would be nice,thanks
http://www.apalansing.com/
Old September 20th, 2006, 05:44 PM   #2
user name
keep your stick onthe ice
user name's Avatar
not if you want to keep fuel injection. the crank sensor is mounted on the bell housing of the magnums. if you wanted to use just the heads and buy an intake to put a carb on you need to use amc lifters for the different oiling system and then figure out the ignintion but im guessing you would want to keep the fi. they would bolt up the same to the trany though.
i think 360 mag short blocks are only like 1300 through sumit
Old September 20th, 2006, 06:09 PM   #3
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
More trouble than it is worth. The aforementioned CPS will keep this from working, as well as the valvetrain. 360s are externally balanced, as well, and the later onse are balanced differently than the early ones. Get a Magnum 5.9.
Old September 20th, 2006, 06:19 PM   #4
Grandman
do i look old !
Grandman's Avatar
yep thats all facts , newer motor including your 94 is a roller cam too . I looked into older heads for my 318 and was not doable . Magnum motors like to crack heads due to there design .
Old September 20th, 2006, 08:23 PM   #5
junk90xj
ALLPRO AUTO
junk90xj's Avatar
ok ill junk it. thanks for the info.
Old September 20th, 2006, 09:49 PM   #6
user name
user name's Avatar
if its a good motor you might want to post it in the for sale section
Old September 20th, 2006, 10:05 PM   #7
PavementPounder
PavementPounder's Avatar
Yeah, don't junk it because you can't use it. That's what is for. :tonka:
(You find people looking for Dodge stuff over there.)
Page generated in 0.20315 seconds with 44 queries
