9in in 1995 bronco and VSS - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 27th, 2011, 10:23 AM   #1
Thetown555
Thetown555's Avatar
Default 9in in 1995 bronco and VSS
I am doing an SAS in my bronco with a d44 in front and 9in in the rear. But stock rearend has the vss on the differential and i am wondering how to convert that to the 9in rearend or ideas on what to do
Thetown555 is offline   Reply With Quote
Old August 28th, 2011, 11:04 AM   #2
Never_Evil
I don't have all the information, but this is what I know.
You will need a tone ring on your carrier, then drill and tap a hole for the VSS to be inserted either into the carrier, or the rear pumpkin. I would do carrier, because it would be easier to get the correct measurements. Gap your VSS to your tone ring and you should be able to have a properly shifting and speedo working Bronco.
Old August 31st, 2011, 05:02 PM   #3
Thetown555
Thetown555's Avatar
ok thanks
Old August 31st, 2011, 05:09 PM   #4
insaneoffroader
insaneoffroader's Avatar
ive seen before a place that makes a replacement tone ring that mounts between your tcase and yoke.
If parts ain't flyin' you ain't tryin'
insaneoffroader is offline   Reply With Quote
Old August 31st, 2011, 05:13 PM   #5
insaneoffroader
heres some quick info for ya
Relocate Rear Abs/Vss Sensor?? - Ford Explorer Ranger Enthusiasts "Serious Explorations"
Old August 31st, 2011, 10:16 PM   #6
Thetown555
Thetown555's Avatar
Huge help i appriciate that link... thanks
Old September 3rd, 2011, 08:34 PM   #7
Thetown555
Thetown555's Avatar
i tryed calling that CPF guy a few times and nothing. anybody no if california pre fun is still in business cus those new mounting setup for VSS is perfect
Old September 5th, 2011, 08:39 PM   #8
Lilmuddy
Lilmuddy's Avatar
I would personally skip the 9" install and sell it to buy a sterling 10.25 that has the speed sensor in it qlready. Plugs right into the factory harness. You will have to reprogram the computer and there is a write up over at FSB on how to do it. Takes about 5 minutes and is NOT difficult. I have gone this route already with my 96. My stuff is all swapped in and I just have to fix the front coil bow.
Lilmuddy is offline   Reply With Quote
Old September 7th, 2011, 05:57 PM   #9
Thetown555
Thetown555's Avatar
looks like i am going with the 10.25 thanks lilmuddy
Old September 7th, 2011, 09:12 PM   #10
Never_Evil
I still would not over look the stoutness of the 8.8" rear. It will be the most plentiful axle at every junkyard under every F150, Bronco, and E150 van and you will be able to keep your 5 lug pattern. You can pick them up less than dirt cheap, and always can get spare axleshafts anywhere you run.
Old September 8th, 2011, 09:12 PM   #11
Lilmuddy
Lilmuddy's Avatar
not a problem, just a different approach thats just as easy of a swap and stronger as long as you find the full float version of coarse.
I dont doubt or am I bashing the 8.8 either. The 10.25 with speed sensor is also found in every F250/350 in the same junk yard. There are some slight differences but basically the same shaft and strength. You mention 5 lug pattern but in his first post he said he was going to do a d44 SAS. May as well upgrade from the knuckle out to 8lug and match the rear while its apart and being rebuilt. Thats the way I did mine. Rebuilt the front with F250 stuff from the knuckle out. Also while swapping the front stuff remember to use 9/16" wheel studs so the lug nuts are the same size as the 10.25 rear.
Old September 8th, 2011, 09:23 PM   #12
jeepster95
Happy 2b Jeepin!
jeepster95's Avatar
i just happen to have a sterling 10.25 373 limited slip disc brake rear end with vss still attached for sale lol. good luck and very nice bronco, i am thinking of the same swap to my daughters f150 shortbed
jeepster95 is offline   Reply With Quote
Old September 8th, 2011, 09:56 PM   #13
Thetown555
Thetown555's Avatar
Im pickin a 10.25 up tomorrow, hopefully it all works good
Page generated in 0.49220 seconds with 63 queries
