durango 4.7 4x4 engine text tip - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 25th, 2011, 07:59 PM   #1
MiNi Beast
MiNi Beast's Avatar
Default durango 4.7 4x4 engine text tip
durango came into the shop today with a lean code, ok right, well it was throwing a lean code and blowing black smoke, there was no o2 activity because it was actually running rich due the power steering pressure switch leaked fluid through the harness to the pcm which caused the connection to be whatever so no o2 sensors which plug harness had traces of power steering fluid as well. So replaced power steering pressure switch, cleaned up harness of fluid, clean up pcm and used electrical contact grease, replaced carbon plugged o2 censors and changed oil. Runs so much better, be back after 1000 miles to change oil again, (built up carbon).
So tip is if pcm has a power steering fluid leak, check the pressure switch. :D
Old September 2nd, 2011, 02:56 PM   #2
chriszildjian17
chriszildjian17's Avatar
this is real common. we get these on a daily bassis in the shop. Not just durango. the dakota,ram, and jeep with 3.7,3.9,4.7,5.7.
chriszildjian17 is offline   Reply With Quote
Old September 2nd, 2011, 02:58 PM   #3
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
weird
RIP FULLSIZE4LIFE
Page generated in 0.18369 seconds with 32 queries
