454 backfire - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 26th, 2011, 08:44 AM   #21
in2deep
Hole tester
intake and its usally just air/fuel once and a while its a flame, cam is good i checked push rods are stright what would be worng with a lifter that would cause that
Old August 26th, 2011, 06:32 PM   #22
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
timing or intake valve related both will cause a backfire into the manifold. like mentioned do a leak down test the valve may have a small notch or bend in it still allowing it to build compression. a leakdown test will show that crack and will not hold pressure if it is cracked or bent
Old August 26th, 2011, 06:44 PM   #23
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
well it could be a burned valve but I tend to think its either a broken valve spring of a wiped exhaust lobe at this point. I would put on a set of oil deverters on the rocker tips(keeps oil from spraying) and fire up the engine with one valve cover removed at a time. watch for anything not moving or very little movement. if its blown lifter the rocker could imitate the effects of a wiped cam lobe. the trick is a blown lifter can be compressed by hand.
the other thing to watch for is an intake valve with a very worn stem. it will "rim" the seat before it settles in to seal and can act like a burn't valve. in most cases will even pass a leak down check.
Yetti
Old August 27th, 2011, 12:37 PM   #24
in2deep
Hole tester
i looked at the cam when the intake was off and did see any bad lobes. but never looked/fondled the lifters. i may just start pulling spark plugs and witch cyl is bad
Old September 2nd, 2011, 03:48 PM   #25
chriszildjian17
chriszildjian17's Avatar
what is the timing set at??
chriszildjian17 is offline   Reply With Quote
Old September 2nd, 2011, 05:10 PM   #26
in2deep
Hole tester
curretly at 8 btdc
Old September 13th, 2011, 06:08 PM   #27
in2deep
Hole tester
well i fingered the problem all intake valves are pitted and one has a obvious bad spot where it leaks thanks guys for help
Page generated in 0.23759 seconds with 44 queries
