Transmission Qustion???? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 23rd, 2011, 08:12 PM   #1
bjkttr
bjkttr's Avatar
Default Transmission Qustion????
OK I am a little confused about what c6 transmission can work with what motor. I have a 390 that I want a c6 transmission with a married transfer case for and I am looking for some help so I know what to buy.So what c6 transmissions are interchangeable with the 390 motor? Also can I take a 390 trans case from a c6 2wd and use the internals from another c6 trans and adapted the married transfer case for a different motor?
bjkttr is offline   Reply With Quote
Old August 24th, 2011, 08:03 AM   #2
bjkttr
bjkttr's Avatar
ttt
Old August 24th, 2011, 08:15 AM   #3
jaysusr
jaysusr's Avatar
Holy cow. Call advance adapters. They know.
Old August 24th, 2011, 08:16 AM   #4
s.hembree
s.hembree's Avatar
You have to find a C6 with a bell housing for the FE (332-428) family of engines.
Old August 24th, 2011, 08:33 AM   #5
Tom
Because racecar
Tom's Avatar
This
Old August 24th, 2011, 09:13 AM   #6
bjkttr
bjkttr's Avatar
i was told if I buy a c6 for a 460 for example and a 390 c6 2wd casing. Then I can take the internals from the 460 c6 trans and put them in the 390 c6 2wd. Also remove the tail shaft and attach the married transfer case to the 390 c6 casing. Will this work?
Old August 24th, 2011, 12:01 PM   #7
Tom
Because racecar
Tom's Avatar
Yes, you just need to swap the output shaft
Page generated in 0.94186 seconds with 44 queries
