Rear Driveshaft balance question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 22nd, 2011, 04:08 PM   #1
2fst4you
2fst4you's Avatar
Default Rear Driveshaft balance question
I broke the ears on the yoke of my driveshaft at the dunes last weekend. I can replace just the rear part that slides off the spline for $65 or I can send the whole driveshaft to a company to be balanced for more.
My question is with that short of a piece does it need to be balanced or will it work fine how it is?
Old August 22nd, 2011, 04:21 PM   #2
Tab
Tab's Avatar
I wouldn't bother balancing it. Make sure the new piece is phased correctly if it isnt splined to go on only one way. How did you break it? Did it bottom out or something?
Old August 22nd, 2011, 04:59 PM   #3
2fst4you
2fst4you's Avatar
It is splined to go on one way only. Its the rear yoke part that slides in and out on the spline. Was just going up a small hill and it broke. What broke was the ujoint b/c I had a bad yoke on the axle which was missing the tab to keep it centered on one side also one of the ubolts was stripped and wouldnt tighten. I kinda ignored it then finally the ujoint went and ruined the ears. Thanks for the help tho ill just order the end piece
Old August 23rd, 2011, 04:50 PM   #4
2fst4you
2fst4you's Avatar
Whats a good way to get the shaft to slide off the spline mines stuck....
Old August 24th, 2011, 09:28 PM   #5
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
hammer?
Old August 24th, 2011, 09:32 PM   #6
capndaveyj
yea i just had to use a hammer on mine to get it off
capndaveyj is offline   Reply With Quote
Old August 25th, 2011, 10:16 AM   #7
2fst4you
2fst4you's Avatar
I tried wouldnt budge ill try again tho thanks ha
Old August 26th, 2011, 12:21 PM   #8
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
WRONG
you have to phase them correctly
Old August 26th, 2011, 12:21 PM   #9
hosejockey4506
Visiting Admin
grow a set and pull it off
Old August 26th, 2011, 12:32 PM   #10
Bones
Bones's Avatar
heat and a hammer
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 26th, 2011, 02:40 PM   #11
2fst4you
2fst4you's Avatar
Ill see what I can do. Haha u try to pull it off a ratchet strap wouldn't budge it!
Old August 26th, 2011, 02:42 PM   #12
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Did u remove the grease zert
H.o.r.e
Old August 26th, 2011, 05:42 PM   #13
Tab
Tab's Avatar
Try putting it in the freezer overnight and then try again in the morning.
Old August 26th, 2011, 08:26 PM   #14
Do you know what maintenance is? For a daily driver, you sure have a lot of problems that no one else seems to have. Have you ever greased your vehicle?
Old August 26th, 2011, 09:40 PM   #15
SoupCan
SoupCan's Avatar
of course he does,when he was doing it he saw the bad yoke and decided to ignore it lol
SoupCan is offline   Reply With Quote
Old August 26th, 2011, 10:11 PM   #16
computeruser
computeruser's Avatar
Between constantly abusing the vehicle and not maintaining it...I pity the person who buys it when he's done with it...
computeruser is offline   Reply With Quote
Old August 27th, 2011, 01:05 AM   #17
2fst4you
2fst4you's Avatar
No why what does that change?
Old August 27th, 2011, 01:07 AM   #18
2fst4you
2fst4you's Avatar
Will do
Old August 27th, 2011, 01:10 AM   #19
2fst4you
2fst4you's Avatar
I do maintenance on it and grease moslty everything obviously just didn't grease that shaft enough and in the future ill make sure to do that more frequently
Old August 27th, 2011, 10:28 AM   #20
Toncomb
Toncomb's Avatar
You forgot to mention it's locked front and rear on 35's.
Originally Posted by Nuggets View Post
Broken jar in butt = Nature's way if dealing with the stupid.
Originally Posted by SweetLeah View Post
Seems that 1/2 these people need to use periods and the other half need to get off their periods.
Toncomb is offline   Reply With Quote
Page generated in 0.35349 seconds with 83 queries
