Back In Black - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 22nd, 2011, 11:06 AM   #21
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
LOL, yes you do - you just don't know it. Your ECU pulls spark with elevatated intake charge temperatures. When you're not driving a decent speed (say, over 25 mph), the underhood air doesn't really have anyplace to go.
So, you're crawling around, cooling fan on, sucking heat into the engine compartment, the exhaust is radiating heat to the frame rails and inner fenders and the entire intake system is soaked with heat. Underhood temperatures rise significantly - and you either dump spark, or you rattle like a PSD.
You don't NOTICE any problems because your rig is overpowered and you can run retarded (heh heh) and not have it affect you. I'm not trying to piss in anyone's cheerios - I just get very aggravated when I see someone go through the trouble to do such a clean and beneficial install and then do something like this.
(it is like me, owning a 50" TV and not having anything but an antenna - true story )
I also realize the Jeeps are "special cases" on these swaps because:
1. There ain't no fawking room left once you stuff a V8 in a TJ;
2. You also have to consider water ingestion about a million times more than someone putting a "cold air" intake on a street car.
I think it would be an easy-ish fix to cure the underhood heat: Build a box around the filter that is closed on all sides and extends up to the hood. Have it seal on the bottom of the hood and either louver the area above it or add a standpipe / mushroom cap or something.
Yep, I agree completely. My underhood iat runs up around 160 right now. I plan on improving that asap. I want to do a box (like you explained) then have it pull air from the top of the hood or cowl.
RIP FULLSIZE4LIFE
Old October 13th, 2011, 04:05 PM   #22
Porscheguy
Porscheguy's Avatar
Little update.... TW fab rims
As it sits now... going to add an antirock, winch, front tube fenders.... need to build front/rear bumpers.... w/ swing out tire carrier for my spare... also have a pic of the quad I put together for the 4yr old(paid $50 for it on CL) was a roller and rusty when it came home!
Porscheguy is offline   Reply With Quote
Old November 3rd, 2011, 09:04 PM   #23
Porscheguy
Porscheguy's Avatar
Going to make my own front sway bar
also pics of the quad in action
Old November 4th, 2011, 04:50 AM   #24
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Very nice clean build, but I'm wondering what differences you noticed when you switched to the recentered H1 wheels....I guessing your rotating mass increased quite a bit from the aluminum wheels you had before. Could you feel a performance loss? I guessing the Dana 30 is now screaming for mercy stuck between a 5.3L and heavy H1's.
Old November 4th, 2011, 05:34 AM   #25
bigbchevy
missmrgreenagain
bigbchevy's Avatar
See? A plumber that wheels in wetlands says I'm right!
Just so you know Porcheguy, I've been calibrating engine controls for about 20 years - specializing in combustion, spark and emissions control.
Oh whatever lol
H.o.r.e
Old November 4th, 2011, 07:00 AM   #26
Porscheguy
Porscheguy's Avatar
I need to beef up my steering and axel now!
Old November 4th, 2011, 09:26 AM   #27
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I like what you're doing for the front swaybar - interested in how you affix the bar ends (splines or other means).
@clarkstoncracker
Old December 15th, 2011, 06:33 PM   #28
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Looks great, Aaron...subscribed. I'm curious to see how you work the front sway bar, as well. Nice work.
Craig
Old December 15th, 2011, 06:39 PM   #29
hondadirtracer
Skymaster
hondadirtracer's Avatar
Forget the Jeep, where are some pics of the Porsche?
hondadirtracer is online now   Reply With Quote
Old December 15th, 2011, 06:54 PM   #30
Porscheguy
Porscheguy's Avatar
Here you go... Its a Euro 1980 1/2 928S 300hp stock with a 5spd(it has headers, rollbar and some other goodies!)
The most complicated POS engine in the World!
Old December 17th, 2011, 08:20 AM   #31
Porscheguy
Porscheguy's Avatar
I would Like to thank ROCKSOLID PERFORMANCE for the quick delivery of my new D44!
Old December 17th, 2011, 09:10 AM   #32
Elusive
Elusive's Avatar
Nice!!!
And thanks for another good read Scooter.
Elusive is offline   Reply With Quote
Old December 17th, 2011, 09:30 AM   #33
Wow, I totally missed all the replies about heat. Yes, I understand it's still hot under there and I probably don't run as good as I could. But, like Scooter said, no room and keeping away from water are a couple major issues. With that in mind, my air cleaner is just behind my headlight where there is air flow around the headlight and also a couple other cutouts in the grill. Second, I have 3 louvers in my hood to help heat exhaust. Not as good as it could be but seems to run good. Maybe I will find a day when I have nothing better to do and I'll figure out a way to reroute it.
Back when I was still running a carb'd engine and an electric fan I had a lot of heat issues. During August at our annual week at the dunes I found removing my hood made a huge difference.
Old December 31st, 2011, 03:39 PM   #34
RossDickman
RossDickman's Avatar
I stared at the first picture for a bit and thought it was holland then looked at the second and knew it! never seen your car though
RossDickman is offline   Reply With Quote
Old December 31st, 2011, 04:25 PM   #35
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Awesome car. I want.
Old December 31st, 2011, 05:16 PM   #36
Porscheguy
Porscheguy's Avatar
It's a fun little car. It has the 300hp 4.7 v8. I paid $1400 for the car and it only took a year to get it running. The 5spd it a little tired but my TJ has been soaking up most of my funds....
Old December 31st, 2011, 05:27 PM   #37
Rob the plumber
I've been eyeing then for a while. A lot of car for little money. I almost traded my yj for one.
Old February 2nd, 2012, 03:40 PM   #38
Porscheguy
Porscheguy's Avatar
Got sick as Hell after the D44 was dropped off... Wife sick... kid..... The cash tree was bare after a TB/WP on the Jetta and Brakes for the 4runner. I was hopeful to make it to JCR to pick up a 1 ton steering kit(prob order a bumper or 2 also) but time ran out as I got the knuckles off the D30.
Old February 25th, 2012, 06:46 PM   #39
Porscheguy
Porscheguy's Avatar
Traded off my old d30 to Mikeb2275 for a nice pair of Hella HID's! Also put in the D44 with the Siperlift Arms, JCR front bumper, new shocks, breaks, hub assy's, and JCR 1 ton steering after I ream the knuckles and pit arm.
Old March 16th, 2012, 10:05 AM   #40
Porscheguy
Porscheguy's Avatar
Took it for a spin today.... still need to have my D&R driveshaft shortened 1.5", front alignment, and some bb's in the beadlocks!
Page generated in 0.44889 seconds with 84 queries
