4.88 R&P DiffCase Question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 20th, 2011, 11:31 AM   #1
09JKULtd
09JKULtd's Avatar
Default 4.88 R&P DiffCase Question
Hey all,
New to the forum. I have a question on my 09 JK Sahara with D30 Front and D44 Rear and upgrading to 4.88s. I have heard that I might need new differential carriers to match the gears when the go in my axles. The parts I have in hand are the matching Ring and Pinions for 4.88s as well as the bearing kits. All the parts are by Motive Gear.
Thanks for the responses in advance.
09JKULtd is offline   Reply With Quote
Old August 22nd, 2011, 02:23 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Originally Posted by 09JKULtd View Post
Hey all,
Depending on what gear ratio is in it now, you may need a new front carrier (and spider gears) to support the new gears. The rear will be fine.
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Old August 22nd, 2011, 04:42 PM   #3
09JKULtd
09JKULtd's Avatar
3.21 is current gear.....
Old August 22nd, 2011, 04:55 PM   #4
Jeeperz Creeperz
GL 4x4 Vendors
You'll need a new Dana 30 carrier and spider gears, or some type of limited slip/locking differential.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Old September 2nd, 2011, 11:21 PM   #5
pigfat
GONE COMMANDO
pigfat's Avatar
you'll also need a new dana 44 carrier. what you should have done is get the thick dana 44 gear to take up the differance, you would have had to ream the holes for the ring gear bolts and you would have been all set.
pigfat is offline   Reply With Quote
Old September 6th, 2011, 03:37 PM   #6
Jeeperz Creeperz
GL 4x4 Vendors
Umm.... He DOES have a thick gear already. All JK 44 gears are thick.
Old September 6th, 2011, 04:42 PM   #7
pigfat
GONE COMMANDO
pigfat's Avatar
My mistake sorry for the bad info. I thought I knew what I was talking abiut but its obvious I didn't. Sirry again.
Page generated in 0.25302 seconds with 44 queries
