1999, 7.3, f350 cranking slow..why? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 19th, 2011, 04:29 PM   #1
219xj
219xj's Avatar
Default 1999, 7.3, f350 cranking slow..why?
i have a late 1999 f350 7.3, zf6. cclb.
ive been having problems with my truck cranking slower than i think it should.. most of the 7.3s that ive heard have starters that turn over the engine really quick... it seems to me that mine isnt cranking nearly as fast... like only one of my batteries is hooked up.. and when im cranking it the lights dim out and sounds like the batteries are drained.... i got both batteries tested and they are good.. the alternator is charging and showing about 15 volts...
is my starter going bad? not sure what its called but is the link between my dual batteries bad? i think its an electrical problem other than anything else.
let me know what you guys think.. any input would be greatly appreciated
219xj is offline   Reply With Quote
Old August 19th, 2011, 04:51 PM   #2
schanxj
schanxj's Avatar
Sounds like it could be a starter solenoid drawing high amps/going bad, loose wires, or corrosion on some of the terminals.
schanxj is offline   Reply With Quote
Old August 19th, 2011, 04:59 PM   #3
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
starter...mine did the same thing...I replaced the batteries and it didn't solve the problem, changed the starter and I was back in business
Old August 19th, 2011, 05:08 PM   #4
Bones
Bones's Avatar
also be sure to check the pos battery cable that runs from the battery to the starter AND the neg cable. I have seen both of those cables with corrosion issues.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old August 19th, 2011, 05:17 PM   #5
Christmas Cookie
did you get my email beater?
Old August 19th, 2011, 05:25 PM   #6
219xj
219xj's Avatar
awesome.. thanks for you help guys ill be lookin at that for sure tonight
Old August 20th, 2011, 08:32 PM   #7
Elvis13
If you pull it (starter) you can have it tested for draw.
Old August 20th, 2011, 10:13 PM   #8
219xj
219xj's Avatar
well i just went out today and got a new starter from advanced.. what a difference. thanks for all the great help guys
Page generated in 0.25230 seconds with 47 queries
