HELP 90 GMC sway bar - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 17th, 2011, 11:54 AM   #1
Jeep ZJ
Jeep ZJ's Avatar
Default HELP 90 GMC sway bar
im having the hardest time trying to get my sway bar end links and bushing bolted up.
it has(not 100% sure) add a leaf, torsion bar turned up not sure if it was "cranked" but did have bad front end parts that where all repalced, and upper arms.
the old links and bushings where broke. i noticed the top bushing on the end link was wore on a real big angle from the upper arm hitting it...
truck runs the streets.
any idea how to get them bolted up?? should i ditch the sway bar??
Old August 17th, 2011, 04:53 PM   #2
jbsjunk
Little Member
jbsjunk's Avatar
The best way I figured is have the weight on the front, not have the tires hanging. Makes the control arm more agreeable.
Old August 17th, 2011, 05:40 PM   #3
Jeep ZJ
Jeep ZJ's Avatar
tried that. could the fact that the arms are built is such way that they will just get in the way period? its the "old style" says dave at cascade4x4...
Old August 17th, 2011, 09:30 PM   #4
Disturban
Disturban's Avatar
Loosen the torsion bars and then put the front tires back on the ground, if the T-bars are cranked it will be harder to get the end links bolted back on.
Old August 17th, 2011, 09:32 PM   #5
Yota Bill
sounds like you need longer links
Old August 17th, 2011, 09:36 PM   #6
Jeep ZJ
Jeep ZJ's Avatar
looked at it tonight and yes they are cranked
yes i did get stock ones....do they offer longer ones at like autozone, napa, ect.??
also it seams to me that if i did get longer ones it still may rub on the end link just not the bushing...
Old August 17th, 2011, 09:51 PM   #7
HVYRTFT
Reed my teef
HVYRTFT's Avatar
You need to return it to stock, and use the stock sway bar links. Why leave them turned up, which is dumb for numerous reasons, if you just run it on the street?
Old August 17th, 2011, 10:09 PM   #8
deerebowtie
Unchained
deerebowtie's Avatar
you can ditch the swaybar, but its bad joo joo for a street-mobile. i'm guessing you're running 33's on a stock 1500? check over on pirate, there's a chart for appropriate torsion bar key selection. also mentioned with part numbers are the incorrect keys. every key has a stamped p/n on it. check out what you have, and evaluate what to do from there.
Old August 17th, 2011, 10:22 PM   #9
Jeep ZJ
Jeep ZJ's Avatar
1 cant afford to SAS it. 2 thats how it was when i got it. 3 it looks good. and 4 it hardly sees road or dirt at the moment but once fixed it will se dirt back roads..
yes 33s that where on it wen i got it. i want to ditch the IFS but at the monent have to stick with it and get it driveable. think u could link me by chance?? ive only looked around pirate like 2-3 times. thanks deerbowtie
Page generated in 0.19099 seconds with 50 queries
