Black Sunshine *It's Alive- Again! - Page 20 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 4th, 2013, 02:29 PM   #381
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
I'm going with a bunch of guys running mid 6's.... I'll definitely be the turd in the group.
I want to see how the tires run out at speed on Saturday before I commit to dragging that thing down there...
Old September 4th, 2013, 04:35 PM   #382
jbsjunk
Little Member
jbsjunk's Avatar
Get a wheels up pic. Don't matter if you top out 1/2 track. Getting there is fun.
Old September 5th, 2013, 05:23 AM   #383
AFRd_CJ5
AFRd_CJ5's Avatar
IIRC, mine went mid/high 6's at 110MPH. I was paying more attention to the MPH because I couldn't launch very hard, so I know the ET wouldn't be good. Only went bottom 1.7 60's. I was leaving at half throttle until about 60-100', then going WOT to the 1/8.
Had a lot of fun though. But yea, I'd definitely want to see how the tires work out at high speed before going there.
AFRd_CJ5 is offline   Reply With Quote
Old September 8th, 2013, 04:33 AM   #384
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
My baby has a new bottle!
We'll get it bolted this week and then see how the new tranny holds up lol!!
Old September 8th, 2013, 04:37 AM   #385
curbdog17
Mini Van
curbdog17's Avatar
Nice
Old September 8th, 2013, 04:38 AM   #386
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
1050 baby bottle lol!!!!
Old September 8th, 2013, 07:55 AM   #387
jbsjunk
Little Member
jbsjunk's Avatar
But, does it blend?
Old September 8th, 2013, 10:52 PM   #388
sandguy356
bronco built for fun
sandguy356's Avatar
Nice
sandguy356 is offline   Reply With Quote
Old September 12th, 2013, 06:19 AM   #389
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Carb is on and she sounds MEAN! Now to get the timing issue figured out. I forsee a new MSD mech advance dizzy in my immediate future
I need to figure out a better way to vent off the oil gasses as well, Maybe another breather in my other valve cover and a 2nd PVC line. I hope I don't have to switch to a vac system...
Lastly some more tinkering with the tranny. Seems to be slipping in 2nd again. Hopefully some slight band adjustments will remedy the problem.
Old September 12th, 2013, 06:28 AM   #390
frdboy
frdboy's Avatar
I would ditch the PCV sys., if you are getting oil pulled in the intake it can cause detonation, maybe that is your timing issue.
Weld a -12 fitting to you V/C and run a hose to a breather tank, in fact I have one I was gonna use on the Mustang I will cut ya a deal on.
Old September 12th, 2013, 06:51 AM   #391
frdboy
frdboy's Avatar
Did you get the o2 bungs in the exh? You can borrow my Wide Band if you want to work on getting your carb dialed in.
Old September 12th, 2013, 08:53 AM   #392
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Yes and yes. Just txt me on the breather tank. I've been researching them this morning. I think that's the way to go. I just still have some blow-by from the new rings. Only 100 miles on it so far. Nothing that is clouding out the exhaust, but it still pushes the dipstick tube out above 7000 RPM's.
Old September 12th, 2013, 08:57 AM   #393
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
ooh.........you dog!!!
Good thing your last name is not Jones, cause I know I can't "keep up" now.
Old September 12th, 2013, 08:59 AM   #394
frdboy
frdboy's Avatar
Do you have a breather and a pcv? pcv's normally go closed at low vac and if you don't have a breather it might build enough pressure to push the dipstick out.
Old September 12th, 2013, 11:38 AM   #395
AFRd_CJ5
AFRd_CJ5's Avatar
You can also do the crankcase evac kit pretty cheap/easy.
Old September 12th, 2013, 12:16 PM   #396
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
PVC and breather are both on the same VC. I think the catch can on the other VC will take care of the whole issue. I've been researching this between projects all day.
evac system may have to be installed, but I want to try this 1st. I really should have a catch can anyways....
Old September 12th, 2013, 12:21 PM   #397
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Looks like that pro-systems carb could use a refresh. They actually do that very inexpensively. A good friend of mine is one of the main builders there.
RIP FULLSIZE4LIFE
SHARPMACHINE is online now   Reply With Quote
Old September 12th, 2013, 12:52 PM   #398
frdboy
frdboy's Avatar
I would look into a locking dipstick for the engine and trans. Fires bring the suck. The trans is easy, just get one from a GM truck and trim to fit. I used a Lokar on my mustang engine for the oil.
Old September 12th, 2013, 12:52 PM   #399
AFRd_CJ5
AFRd_CJ5's Avatar
Brad?
Old September 12th, 2013, 01:28 PM   #400
jbsjunk
Little Member
jbsjunk's Avatar
Shouldn't those be in opposite covers so it pulls in thru the breather in one cover to the pcv in the other?
Might be a Ford thing...
Page generated in 0.46831 seconds with 83 queries
