xj tj swaybar swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 12th, 2005, 10:14 AM   #1
scorpio_vette
scorpio_vette's Avatar
Send a message via MSN to scorpio_vette Send a message via Yahoo to scorpio_vette
Default xj tj swaybar swap
just wondering if a xj front swaybar is the same length/size as a 97 TJ. i seem to have a hard time finding a used TJ swaybar.
scorpio_vette is offline   Reply With Quote
Old December 12th, 2005, 11:00 AM   #2
$500 MJ
MJ conosuer
$500 MJ's Avatar
Send a message via MSN to $500 MJ
I know rusty's sells the adjustable ones to fit both Jeeps, but that helps you in no way at all. I am pretty sure that they are as I put a TJ one on mine last spring, but its now shot and I need to replace it. Length might be the reason why.... IDK
$500 MJ is offline   Reply With Quote
Old December 12th, 2005, 04:11 PM   #3
Sonicjay
That would be a Trackbar, not a sway bar.
Sonicjay is offline   Reply With Quote
Old December 12th, 2005, 11:17 PM   #4
$500 MJ
MJ conosuer
$500 MJ's Avatar
Good Catch, I guess I have the track bar on my mind cause I just ordered one of them, sorry for all the confusion....
Old December 13th, 2005, 12:17 AM   #5
scorpio_vette
Unhappy
now i still don't have an answer
Old December 13th, 2005, 11:59 AM   #6
FlatFender
Tap Tap Splat
FlatFender's Avatar
im gonna say no. they are not the same.
Old December 13th, 2005, 01:27 PM   #7
xjjeepthing
XJ Slut
xjjeepthing's Avatar
Send a message via Yahoo to xjjeepthing
I believe the bar from a XJ is a bit wider then the wrangler , havent measured but looking at my XJ and my friends Wrangler not the same.
xjjeepthing is offline   Reply With Quote
Old December 13th, 2005, 01:56 PM   #8
scorpio_vette
i just thought of that possibility, because people (including myself soon) are swapping XJ front axles under the TJ's for the high pinion. so i just assumed that if the axle was the same (bolt in), then the swaybar should be pretty damn close. yes/no???
Old December 13th, 2005, 03:38 PM   #9
Tonka
Tonka's Avatar
no, the swaybars are very different. tj may work in an xj but xj will not work in a tj
Old December 13th, 2005, 04:00 PM   #10
scorpio_vette
thanks
Page generated in 0.26261 seconds with 53 queries
