wont start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 14th, 2011, 05:48 PM   #1
bronco 2
Default wont start
i have an 87 bronco 2 sat for a few months. ran fine before. no fuel pumps running. so i hard wired both fuel pumps. no they work and i have fuel at the rail. but it still wont start. good spark. could this be a bad ecm. could the interta swicth cause the fuel injectors not to work.
thanks Ean
bronco 2 is offline   Reply With Quote
Old August 14th, 2011, 05:53 PM   #2
xjmichigan
xjmichigan's Avatar
hello wrlcome to gL4x4 sounds lik you have bad gas by pass the interna switch and test it
Old August 14th, 2011, 05:56 PM   #3
bronco 2
do u just connect the wires together or must u put 12 volts to it. or ground
Old August 14th, 2011, 06:07 PM   #4
tweak177
Say what?!?
tweak177's Avatar
tweak177 is offline   Reply With Quote
Old August 14th, 2011, 06:11 PM   #5
bronco 2
please dont right pointless things on here your not helping and its just plain rude. so i bypassed the inertia swith and still nothing could it be a bad pcm.
Old August 14th, 2011, 06:57 PM   #6
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Settle down JR. If you put things in complete sentences it is lots easier for us to read and under stand what the fukc your saying. Do you have fuel at the rail? Good pressure? There is a switch behind the glove box that goes to shit on RBV some times.
Old August 14th, 2011, 08:01 PM   #7
bronco 2
yes i have fuel at the rail, and it has good pressure. I had to hard wire the low pressure, and high pressure pumps to get fuel. I bypassed the fuel pump switch just to be sure. Does any body know if the pcm could cause this. I have good spark. If i dump fuel in the throttle body it starts briefly. will the fuel pump shut off switch cause the injectors not to pulse. or does it just cause the pumps not to work.
Thanks everyone
Old August 14th, 2011, 08:02 PM   #8
xjmichigan
xjmichigan's Avatar
Test it by putn a pos grd to the pcm the grounds go bad and wil not work
Old August 14th, 2011, 08:08 PM   #9
lilbigfoot93
cant cash my checks
lilbigfoot93's Avatar
have your ignition moduale tested on the distributor (remove the mod and take it to a auto store for testing) i have had problems in the past with weird starts and running issues
lilbigfoot93 is offline   Reply With Quote
Old August 14th, 2011, 08:11 PM   #10
bronco 2
Can the module cause all of the problems? No fuel pumps and the injectors not pulsing?
Old August 14th, 2011, 08:44 PM   #11
Bishop
Bishop's Avatar
If it starts to run when fuel is added to the throttle body, it is not your ignition. I'd look into your fuel more.
Old August 14th, 2011, 08:48 PM   #12
jaysusr
jaysusr's Avatar
Go rent a set of noid lights to test for injector pulse
Old August 14th, 2011, 08:48 PM   #13
jaysusr
jaysusr's Avatar
Or just buy a crank sensor and throw er on. See if that does it.
Old August 14th, 2011, 09:06 PM   #14
Bishop
Bishop's Avatar
Also, the interna switch is meant to cut fuel in case of an accident.
Old August 15th, 2011, 12:16 AM   #15
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
Originally Posted by jaysusr View Post
or just buy a crank sensor and throw er on. See if that does it.
x2
Old August 15th, 2011, 12:18 AM   #16
osteologation
http://fordfuelinjection.com/
This will tell you how to test your sensors.
Old August 15th, 2011, 02:16 AM   #17
michigan_Redneck
semi-pro web crawler
michigan_Redneck's Avatar
Send a message via MSN to michigan_Redneck Send a message via Yahoo to michigan_Redneck
Also check out www.therangerstation.com
more info about ford ranger than anyone person should know!!!
sounds to me like a bad ground, ignition module, or ECM
its odd you would have spark but no pulse.
Also check for ECM codes, EVEN if you don't have a check engine light
ALSO, what motor??? - NVM 87 B2 only had the 2.9L
michigan_Redneck is offline   Reply With Quote
Old August 15th, 2011, 08:13 PM   #18
you are
or
you're
Page generated in 0.45074 seconds with 77 queries
