1996 f150 problems. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 14th, 2011, 05:04 PM   #1
fordboy08
fordboy08's Avatar
Default 1996 f150 problems.
I bought this 96' f150 and now the problems are starting. Here is a list I need help with.
1- trany pan won't stop leaking. Changed the gasket twice.
2. Gauge lights don't work. Put in a new switch and everything.
3. Power locks won't work and replaced the switch.
I checked all fues and everything. I am stumped on this.
fordboy08 is offline   Reply With Quote
Old August 14th, 2011, 05:06 PM   #2
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Com problems with that year
H.o.r.e
Old August 14th, 2011, 05:07 PM   #3
bigbchevy
missmrgreenagain
bigbchevy's Avatar
DDo your headlights still work on low beam?
H.o.r.e
Old August 14th, 2011, 06:52 PM   #4
fordboy08
fordboy08's Avatar
Ya. Tail lights, and running lights work also.
Old August 20th, 2011, 09:47 PM   #5
Never_Evil
With the tranny pan, get rid of the cork gasket or rubber gasket. Put a 1/4" bead of black, non drying RTV. It will keep a seal better and is resistant to the fluid. DO NOT OVER TIGHTEN TRANNY PAN BOLTS!!!!!!!!!!!!!!!!!!!!!!!! Much like your intake manifold or your wheels, you must do the bolts in sequence and stepped torque increments. Start in the middle and criss cross your way out and start with 5 INCH-pounds of torque. Step it up and do 3 or 4 passes until you reach your final torque requirement.
Page generated in 0.34813 seconds with 38 queries
