8.25 29 spline - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 19th, 2006, 12:58 PM   #1
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
Default 8.25 29 spline
Does anyone sell lockers for these. It seems other than a Limited slip or a select few lockers (arb) I can't seem to find one. should I just down grade to the 27 spline axles?
ckupq is offline   Reply With Quote
Old September 19th, 2006, 01:14 PM   #2
PavementPounder
PavementPounder's Avatar
I would upgrade the axle. If you don't want to deal with an 8.8 conversion or go heavy, Cooter has XJ D44's. Plenty of locker choices for those.
Old September 19th, 2006, 01:16 PM   #3
ddeadserious
ddeadserious's Avatar
I have a PowerTrax No-Slip locker in my 8.25.
PavementPounder - Are there any disadvantages to the 8.25? Is it weak or something?
ddeadserious is offline   Reply With Quote
Old September 19th, 2006, 01:27 PM   #4
xj4life
xj4life's Avatar
there is a 29 spline Detroit Locker
Old September 19th, 2006, 01:39 PM   #5
PavementPounder
Well, its not "strong". The way I see it, its one of those axles that isn't worth dumping money into, but at the same time isn't exactly garbage if you aren't running that large a tire or not throwing a lot of power through it. Kind of like a C20 from a CJ - they are everywhere and everybody wants to get rid of them for cheap or free. So, I just left my CJ on 33's stock and have a small pile of complete assemblies to swap in or pull parts from. I haven't even spun my factory hubs yet with 14.5" wide TSL's and aggressive higher-rpm clutch engagement, though I do have a set of 1-pc shafts on hand. :tonka:
I figured that if he was going to go through the trouble of doing anything to the axle, he might as well put forth effort in the better direction - especially since a bolt-in option exists. If you can get a locker, fine. But I wouldn't swap in a weaker shaft just to get a locker that might break the weaker shaft.
Old September 19th, 2006, 02:22 PM   #6
lowlock
05 LJ in progress
lowlock's Avatar
I just got a ARB for my 8.25
lowlock is offline   Reply With Quote
Old September 19th, 2006, 02:31 PM   #7
ckupq
ckupq's Avatar
I guess my problem is being a college student I'm looking for a cheap simple option without having alot of downtime. swapping over a D44 would just be a pain IMHO. I don't need it. I'm only going up to 31's and they're pretty bullet proof till you hit 33's. I was just hoping on finding someone making a lunchbox a cheaper locker or Limited slip. Honestly if I go that route I might go detroit but prolly won't buy it till I get other things done (tow points, lift).
Right now I'm trying to find one for later install. I need tow points and other things first, but it doesn't hurt to do the research first.
Old September 19th, 2006, 03:06 PM   #8
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Powertrax No-Slip, Detroit Locker, ARB (in order of cost, $ to $$$$)
Old September 19th, 2006, 03:44 PM   #9
ckupq
ckupq's Avatar
does powertrax make a 29 spline? I can only find the 27 spline one when I look.
Old September 20th, 2006, 05:35 PM   #10
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
the 8.25 housing is stronger than a D44, ring and pinion are the weaker point(D44 2 1/2" tubes vs. 8.25 3" dia tubes) Powertrax makes one for the 29 spline Essentials(www.quadratec.com) carry it for $409.99
nick_n_ii is offline   Reply With Quote
Old September 20th, 2006, 07:29 PM   #11
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Rocky road has the cheapest powertrax prices I could find when I had my XJ.
@clarkstoncracker
Old September 20th, 2006, 07:36 PM   #12
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
You want a cheap locker, ever hear of a Lincoln Locker?
Page generated in 0.96821 seconds with 59 queries
