1991 F150 4x4 doesnt work... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 11th, 2011, 05:51 PM   #1
85F250460
gettin shit done
85F250460's Avatar
Default 1991 F150 4x4 doesnt work...
I recently traded my jeep for a 1991 F150. The kid I got it from said the whole front axle is bad (twin Ibeam suspension) he gave me the whirl front axle or what ever you wanma call it. I'm curious if I could just take the gears out of extra the axle he gave me and put it in the one in the truck. And I noticed the steering box leaking and the trucks all over the road. Any suggestions?
85F250460 is offline   Reply With Quote
Old August 11th, 2011, 05:56 PM   #2
HVYRTFT
Reed my teef
HVYRTFT's Avatar
if the axles are both of the same style, (i.e. both ttb) then you can swap the gears as long as they match the rear. But you should also take a look at why it's wandering so bad. Look at the ball joints and tie rod ends. Jack it up by the frame and wiggle all the moving parts and check for slop. Don't forget an alignment after you install any steering parts.
Old August 11th, 2011, 07:22 PM   #3
85F250460
gettin shit done
85F250460's Avatar
Ok thanks. Definitley gonna do that
Old August 14th, 2011, 01:03 PM   #4
85F250460
gettin shit done
85F250460's Avatar
I put it in 4 Lo put it in reverse and kind of torqued on the gas with my foot on the brake and it slips out of 4x4. It's not the transfer case, the axle is like slipping. I'm not sure if its lock out hubs or what. Amy advice would be appreciated
Old August 14th, 2011, 01:23 PM   #5
chriszildjian17
chriszildjian17's Avatar
I think the best thing to do is tear apart the front axle. check for worn, or broken parts. You will be able to tell whats going on there. The ford factory hub lock are notorius for going out. I sell parts at a ford/chrysler dealer and we do go threw a ton of those.
chriszildjian17 is offline   Reply With Quote
Old August 14th, 2011, 06:23 PM   #6
85F250460
gettin shit done
85F250460's Avatar
Yup, I just replaced the locking hubs and that was it thanks a lot. I know I gotta replace the passenger side axle ujoint is that hard on these old fords?
Old August 15th, 2011, 07:26 AM   #7
chriszildjian17
that depends on how much dirt and rust there is. other than that it's real easy.
Page generated in 0.20991 seconds with 44 queries
