**Feeler** 1995 Ranger RCLB 2WD w/5.0 HO and AOD - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vehicle Part Outs
Old August 10th, 2011, 09:41 PM   #1
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Default **Feeler** 1995 Ranger RCLB 2WD w/5.0 HO and AOD
Built this last winter and don't really drive it much, so maybe there is enough interest in the parts on it.
Body is decent
New rear spring hangers and shackles - $75
8.8 rear 3.27 gears WELDED with drum brakes $200
Full MSD ignition 6AL box/billet vacuum advance dizzy/blaster coil $450
Full roller 5.0 HO with Summit branded edelbrock RPM air gap/600cfm edelbrock carb, FMS rolloer rockers and B303 cam heads are E7 with recent re-work. Dual sump pan with Melling high volume oil pump. March performance serpentine kit with short water pump. - Maker offer for parts or complete
17" Mustang Pony wheels with blank center caps and Barnum Bravius II 225/45-17 tires. - $400
2wd AOD with Art Carr manual valve body, push button O/D, also has ACC Boss hogg converter 22-2500 stall, Sonnax A++ overdrive servo, and hardened input shaft. $700 Complete or $550 for the performance parts(no trans)
Here is the build thread with some pictures
2wd Ranger Build - Now With AUDIO - Great Lakes 4x4. The largest offroad forum in the Midwest
Let me know what you're interested in and we will negotiate a price.
Old August 11th, 2011, 04:49 PM   #2
cannaert
No more Jeep
cannaert's Avatar
How much as a complete truck?
Old August 11th, 2011, 04:59 PM   #3
koochman450r
koochman450r's Avatar
willing to seperate tires and wheels?
you won this battle.
Old August 11th, 2011, 07:01 PM   #4
bigblockford79
Big Block Ranger
I would like $3500 or trade for a 4x4 Ext Cab Ranger or something similar.
As a whole vehicle it needs - Front main seal is leaking, valve cover gaskets are leaking, windshield wipers only work currently with a toggle switch. The wiper issue I believe to be the GEM module, I haven't been able to find one yet. I can take more pictures if you like, I have put around 2000 miles on it since I finished it this spring and until the seal started leaking there were no issues. I got 16.7 mpg with it the only time I checked mileage, this was from Hamilton to Fremont via us-31 without using overdrive and shifting rather aggressively. It should easily be capable of 20+ if shifted sooner and O/D was used.
Originally Posted by koochman450r View Post
willing to separate tires and wheels?
Will see how everything goes, If I do you have first dibs.
Page generated in 0.18590 seconds with 36 queries
