Comp Rig for sale. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 10th, 2011, 04:32 PM   #1
Bruised
Default Comp Rig for sale.
Posting this for a friend that works at 4wd Hardware.
After 7 years of competition, I've decided this is my last year and it's time to get rid of the rig. I'm planning to build a house and I want something I can drive every day and enjoy on nice days. So I'm not completely done with jeeps yet. I also still plan to raise money for our Crawl to Cure Cancer project.
Comp Rig Specs:
Custom Metallic Pink – Crawl to Cure Cancer stock mod competition rig – PPG paint – you get what’s left of the paint too
Titled as a 1997 Jeep Wrangler SE – I have the title
Only thing left from 97 is the frame
We replaced the tub (2 years ago) with a tub from a 2000 TJ
4.3L Vortec motor with 4L60E automatic transmission
Motor is out of a 2003 GMC 1500 2WD truck. Had 1,000 miles on it when I put it in the jeep in 2006. Probably have put on less than 2,000 miles.
Advance Adapters motor mounts
35x12.50-15 Pro Comp Xtreme Mud Terrains tires mounted on 15x8 Eaton bead locks with 5 on 5.5” BP
4” Full Traction Long Arm Suspension with 1” body lift
Bilstien 5100 series shocks front and rear
Warn 9.0 RC winch on the front with custom pink Master Pull winch line
Warn 2.5 winch mounted in the rear of the tub to compress the suspension
Mounts on the axles to hook the winches to for compression
Both winches wired with in-cab switches
Access panels in the floor to get to the t-case and drive shafts easier
Front axle: Custom built by Solid Axle Hybrid 44/60: 44 center section with 60 outers. 5.13 G/2 gears and ARB air locker, Chromoly custom length Dutchman 35 spline axle shafts with CTM u-joints
Rear axle: Custom built Rock Jock 60 center section, 35 spline chromoly axle shafts, 5.13 G/2 gears with ARB air locker.
AGR Hydro-assist steering set up, includes steering box, ram and steering pump
PSC steering pulley
Steering cooler mounted inside the grille
Custom built roll cage to WeRock specs tied into the frame in 6 places. Made of 1-3/4 .120 wall DOM
Mastercraft suspension seats tied into the cage and 5 point harness
Mastercraft custom black with pink piping seat covers
Art Carr shifter for 4L60E transmission
CNC dual handle cutting brakes
Gen Right Off Road front grille hoop
Body Armor front winch plate with aluminum fairlead
Flaming River non-tilt steering column
Flaming River steering wheel
Flaming River steering shaft
JE Reel front and rear drive shafts
Atlas 2 transfer case with 4.3 ratio
Painless universal wiring harness and Howell harness for the motor
Interior and underside of tub is Line-X
Be Cool Conversion Radiator
Flex-a-Lite Black Magic Fan
TNT Customs Phantom Tube Fenders with about 3” added to the outside to fit WeRock rules
Gen-Right Custom Corner Guards and rock sliders
JKS Engine skid plate
Mean Green alternator and starter
Royal Purple fluids
Custom dash with Auto Meter Ultra Lite gauges
Under body pink LED rock lights
Truck Lite LED work light headlights
LED tail lights
Kilby On Board Air Kit
Fiberglass TJ hood with hood pins from Summit Racing
Jet ski kill switch and Flaming River master kill switch
MSD High Pressure Fuel filter
2.5 gallon Poly Performance vertical fuel cell
Dual Yellow Top Optima Batteries mounted in the rear of the tub with Gen Right Battery tray
Painless Wiring switch panel. Controls front and rear winches, OBA, front and rear air lockers, line lock.
Additional switches for rock lights and head lights
2 blue ant radios and 3 helmets
Spotter straps and window nets
In addition to all of this, you also get all of the spare parts that fill the 6’ bed of my truck (minus the chairs and jack you see in the picture). That is everything from:
Spare Mean Green alternator
Spare axle shafts (front and rear) with the fronts already put together with CTMs installed
Spare drive shafts (front and rear)
One new tire mounted on Eaton bead lock wheel
Spare conversion radiator
4 spare Bilstien 5100 series shocks
Spare winch line
Cases of Royal Purple fluid (diff, trans and steering)
Plus much more. The bed of my truck is full of spare parts
Everything you need to start competing! It's been a competition rig/weekend wheeler, so it does have some dents, scratches etc. I can take more pictures if you want.
Asking $19,000 or best offer. I’m not interested in any trades. Will deliver within reason. I’m located in Lisbon, OH.
If you want more pictures or additional information, you can send me a PM or shoot me an email at kyoung@4wd.com.
Pics are at this link
Comp Rig For Sale - NEC Online Community
Bruised is offline   Reply With Quote
Old August 16th, 2011, 06:29 PM   #2
Bruised
Still for sale.
Old August 18th, 2011, 08:08 AM   #3
TJMagoo
Thanks Bruised for posting this for me.
The rig is still for sale and I am very motivated to get rid of this thing and start on my next project. The price is very negotiable - so make me an offer.
I have the parts list for everything that is on it and what comes with it and it totals over $49k so this is a steal for this price.
TJMagoo is offline   Reply With Quote
Old August 18th, 2011, 08:09 AM   #4
TJMagoo
Pics...
ID:	82526   Click image for larger version
ID:	82527   Click image for larger version
ID:	82528   Click image for larger version
ID:	82529   Click image for larger version
Old August 22nd, 2011, 10:26 AM   #5
TJMagoo
New price $18k or best offer. Make an offer.
Old August 23rd, 2011, 07:26 AM   #6
TJMagoo
Btt
Old August 25th, 2011, 09:55 AM   #7
Bruised
Bump it up!
Old August 29th, 2011, 10:25 AM   #8
TJMagoo
Btt - still for sale. $18k or best offer. Make me an offer.
Old September 1st, 2011, 03:28 PM   #9
TJMagoo
Btt
Old September 5th, 2011, 11:54 AM   #10
TJMagoo
Sold
Page generated in 0.35565 seconds with 55 queries
