The Ruffstuff NOT Universal 4 Link Kit! - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Great Lakes 4x4 Marketplace > Vendors
Vendors Companies That Deliver Great Products Or Services and a list of companies offering GL4x4 Discounts
Thread Tools
Old August 9th, 2011, 09:03 PM   #1
Gravel Maker
Steel Hauler
Gravel Maker's Avatar
Arrow The Ruffstuff NOT Universal 4 Link Kit!
First off I should explain my thoughts so this dosen't sound too strange to you guys.
A few years ago I started seeing brackets that completely disregarded all the rules about Link Suspensinons as we knew them to be. The changes that have come to be accepted as the way to do it no longer care about seperation, not vertical or linear. Did those rules change overnight? No, they didn't. What changed was a few companies saw a way to make things easier, for them and the many people that bought into the idea. Now every company making anything for link suspensions has these. Why don't we?
We do not make a combination upper/lower link bracket with 4" (or less) of vertical seperation and no inches of linear seperation. I simply do not agree with it. It certainly makes installations easier but it also limits you to only what you can do using that type of bracket.
Our Link Brackets are not holding you to any pre-determined limits. Our Link Brackets ALLOW you to make your rig work as well as you can design it. Not limiting you in any way.
I know I am going to get some flack for this but I believe everyone is entitled to an opinion and this is mine. Anyway here they are, our new 4 Link Kits!
For Framed Rigs
This is it, everything in one package for a great price, and not low end stuff just to be cheap either! The kit is wrapped around 8 of our 1.25" Heat & Cryo Treated 78,000lb+ RSL Chromoly Heims with Stainless High Misalignment, Zink Plated Jam nuts, and 1.5" Tube ID Weld Bungs. Not a cartridge type joint in sight.
The Upper Frame brackets are our 25 degree 5 way Adjustable link brackets. The Lower Frame brackets are our venerable Chassis Link brackets, time tested and proven for optimum performance.
For the axle end we have our Axle Mount Link brackets and our New Truss that we have refined for additional strength while shedding uneeded pounds. On the Truss we keep it simple with 4 of our 3/8" thick Flat Bottomed Link Tabs.
For Tube Chassis Rigs
Everything on the axle is the same as the other but the tube side is different.
The Upper Chassis brackets are our 10-35 Degree 5 Way Adjustable Tube Mount Link brackets. The Lower Chassis brackets are 10-35 Degree 3 way Adjustable Tube Mount Link brackets for optimum performance.
The only choice you need to make is if the Truss needs to span a Large third member (D60, D70, 14 Bolt, Sterling, Eaton, Dodge 9.75, etc...) or a Medium sized third member (Ford 8.8, D44, Ford 9", Toyota, etc...). If you want to make more changes give us a call and we can see what we can do!
These are on Special @ $722.50 for the framed and $663 for the tubed as you see them, about 15% less Than normal prices...
http://www.ruffstuffspecialties.com/catalog/34LINK.html
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Your Fabrication Parts Source
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old August 18th, 2011, 01:14 AM   #2
Gravel Maker
Steel Hauler
Time to link it up, I always liked the fact that you don't have to do it all at one time. You can take your time and do one end now and the other end later!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old August 23rd, 2011, 12:45 PM   #3
Gravel Maker
Steel Hauler
But it is time to get started ;)
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old September 12th, 2011, 11:28 AM   #4
Gravel Maker
Steel Hauler
Thanks forthe orders this weekend, 2 of these heading to Michigan today!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old September 25th, 2011, 02:36 PM   #5
Gravel Maker
Steel Hauler
Time to get this back in front of you!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old September 30th, 2011, 12:59 PM   #6
Gravel Maker
Steel Hauler
Thanks for a very busy month!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old October 6th, 2011, 10:06 PM   #7
Gravel Maker
Steel Hauler
Time to load up for the Off Road Expo!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old October 14th, 2011, 11:26 AM   #8
Gravel Maker
Steel Hauler
This is the single most performance related item you can do to your Jeep, 200hp more won't help if your suspension can't keep up!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old November 10th, 2011, 10:06 PM   #9
Gravel Maker
Steel Hauler
To put it in a nutshell ;)
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old November 29th, 2011, 08:06 AM   #10
Gravel Maker
Steel Hauler
The best price for the best kit ;)
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old December 3rd, 2011, 08:48 PM   #11
Gravel Maker
Steel Hauler
These can be set up with way too many options to make it perfect for YOUR rig!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old December 7th, 2011, 12:43 AM   #12
Gravel Maker
Steel Hauler
Only the best so you can do your best!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old December 12th, 2011, 11:20 AM   #13
Gravel Maker
Steel Hauler
Time to go linked? No better way!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 4th, 2012, 01:38 PM   #14
Gravel Maker
Steel Hauler
The right way of doing things, your way!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 23rd, 2012, 08:35 PM   #15
Gravel Maker
Steel Hauler
All parts are in stock!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 29th, 2012, 12:20 PM   #16
Gravel Maker
Steel Hauler
Thanks for all the sales using the GL4X4 discount code!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old February 29th, 2012, 08:07 PM   #17
Gravel Maker
Steel Hauler
These are in our top ten, thanks!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old March 12th, 2012, 12:45 PM   #18
Gravel Maker
Steel Hauler
Time to get a kit coming your way!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old March 15th, 2012, 02:11 PM   #19
Gravel Maker
Steel Hauler
Its always a good time to link it up!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old March 21st, 2012, 08:03 PM   #20
Gravel Maker
Steel Hauler
Got started on my FJ45 suspension today, hung the front axle...
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Thread Tools
Page generated in 0.40044 seconds with 83 queries
