Chimney Draft stopper balloons? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 9th, 2011, 02:46 PM   #1
84Scrambler
Default Chimney Draft stopper balloons?
Anyone use something like this in their fireplace?
http://www.amazon.com/Fireplace-Chim.../dp/B0001HA8MC
If so, do you notice a difference in air leaks, utility bills, etc?
Are there better options to seal a fireplace?
Old August 9th, 2011, 02:54 PM   #2
mschaffer66
mschaffer66's Avatar
No, but I bet barry is gonna need one for his anus pretty soon...
Old August 9th, 2011, 02:55 PM   #3
xjmichigan
xjmichigan's Avatar
Fill it with your natural gas.
I have one, works, but not as good as my custom hard foam/plywood I made
Old August 9th, 2011, 03:04 PM   #4
curt1656
Praise the lowered
curt1656's Avatar
I tried them but they kept catching on fire.
Old August 9th, 2011, 03:19 PM   #5
Disco Stocker
№ ℮ Ђ ώқ Θה ς├│ﺝ
Disco Stocker's Avatar
I just use this roof top damper
nice write up
http://www.superiorchimney.net/firep...ney-flues.html
Disco Stocker is offline   Reply With Quote
Old August 9th, 2011, 04:12 PM   #6
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
He is gonna wish his day had went a lot different, and not much love from GL4.4bromance club either.
I plug mine (6" cap or whatever it is called) from the roof when done using the wood stove, then remove it before burning again?????
RIP FULLSIZE4LIFE
Old August 9th, 2011, 08:53 PM   #7
84Scrambler
I want something that can be easily put in and taken out. We don't use the fireplace much during the winter, but we enjoy it once in a while. Thought this pillow thing might be the ticket. If it cuts down on even 80% of the leakage it would be a huge savings.
Old August 10th, 2011, 04:53 PM   #8
Grifter
Human Hunter
Grifter's Avatar
nice write up
This...
I worked for a chimmney repair/sweep for a few years. We installed these regularly for right under $200.
Effective solution. Has a rubber gasket that when you pull down on the cable seals up against the top of the Flue tile. A simple bracket bolts to the wall of the fire box and a piece of chain at the bottom of the cable slides into grooves cut in the bracket when you lull down on the damper lid.
Great warranty also as I recall..
Grifter is offline   Reply With Quote
Page generated in 0.25009 seconds with 46 queries
