2005-2006 Jeep liberty CRD Parts for sale - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 9th, 2011, 02:36 PM   #1
glh_turbo22
glh_turbo22's Avatar
Default 2005-2006 Jeep liberty CRD Parts for sale
I don't know if anybody on here has one of these or knows someone that does, but I have a lot of new parts for sale for these vehicles.
All parts are brand new and genuine replacement OEM parts.
4-Bosch High pressure injection pumps. New - $1000 (These sell for close to $4000)
10-Bosch MPROP Valve. This is the electric valve that goes on the high pressure injection pump. New-$100.
10-Bosch Boost/Air temp sensors. New - $80 (autozone charges $125)
10-Bosch Cam Sensor. New - $50 (autozone charges $45 for a duralast knockoff)
1-Garret Turbocharge with new gasket. New-$300
10-Bosch Fuel rail pressure sensor. New - $200 (autozone charges $300)
10-Bosch crank position sensor. New - $80 (autozone charges $75 for the duralast knockoff)
4-Bosch injectors. New $200ea (that less than half what others are charging)
More parts to come soon.
Thanks.
glh_turbo22 is offline   Reply With Quote
Old August 9th, 2011, 02:42 PM   #2
FlamingTomato
You break it - You fix it
FlamingTomato's Avatar
got a flow control valve? the servo went out on mine and now it get's the "flutters"
FlamingTomato is offline   Reply With Quote
Old August 9th, 2011, 02:44 PM   #3
glh_turbo22
Are you talking about the throttle valve near where the intake tube attaches?
If so I will need to check.
Old August 9th, 2011, 02:47 PM   #4
FlamingTomato
Yep, the butterfly valve that creates a touch of vacuum turbulence for the egr to work properly. Drivers side of engine - just before the erg unit.
Vacuum under pressure - Good one Chrysler
And yes that too -----------------------------------\/
Old August 9th, 2011, 02:55 PM   #5
glh_turbo22
It's actually there also to aid in shutdown of the engine. Especially in cases of oil ingestion into the engine (like from a blown turbo seal). It shuts when the key is turned off so in the event of a runaway it cuts off the air since that's the only way to stop it from destroying itself.
I'll look to see if I have one and get back to you.
Old August 15th, 2011, 10:14 AM   #6
glh_turbo22
Doesn't look like I have one, sorry. Let me know if you need anything else.
Old November 29th, 2011, 01:23 PM   #7
glh_turbo22
Everything Sold
Old January 24th, 2012, 09:06 PM   #8
jmbeam
Unhappy
How did you sell all of these parts so quick or did someone purchase them all to resell? I just purchased a CRD and it looks like I may be needing parts.
jmbeam is offline   Reply With Quote
Page generated in 0.22597 seconds with 47 queries
