1982 cj7 - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 20th, 2011, 04:05 PM   #81
reptile610
reptile610's Avatar
Send a message via AIM to reptile610 Send a message via MSN to reptile610 Send a message via Yahoo to reptile610
so it's been mentioned that my shackles lean because they're oversized. should i even bother putting originals back on or is it plenty safe as it is?
reptile610 is offline   Reply With Quote
Old October 22nd, 2011, 01:31 PM   #82
cerial
Direct Drive FTW
cerial's Avatar
Find a older Chevy running a 465. Call advanced and get a bell housing to mount that iron duke to the 465. Get some 10/14 bolt axles with a 373 ratio and you will be golden.
The little motor does not put out much power. But, with the 465 behind it you will have a impressive level of torque to wheel off road without worrying about breaking stuff.
On road the 2.5 will give you decent fuel mileage. Just don't expect it to have much power at highway speeds.
I have had 3 Jeep 2.5 and 9 Chevy 2.5 engines. I like these engines although they are getting harder to find. They are really tough to kill and are easy to work on and maintain.
Just don't try to make power with them cause it is just not worth it. Use gearing to make power and you will have a very reliable/capable rig.
Just my 0.02
Old October 22nd, 2011, 08:34 PM   #83
reptile610
reptile610's Avatar
Just my 0.02
i have heard this before but im worried about after i regear to keep what little power i have and then put my 35s on it that i wont be able to drive on the freeway at all. i refuse to have a trailer queen.
Old October 22nd, 2011, 08:39 PM   #84
reptile610
reptile610's Avatar
i showed that bell housing who's boss tonight. beat it with a hammer to free it up.
inside of it
think i need a new clutch?
do i NEED to do anything to the flywheel? i plan on swapping the motor eventually. really don't wanna have to spend anymore money on a flywheel that will be leaving with the engine.
Old October 22nd, 2011, 08:40 PM   #85
reptile610
reptile610's Avatar
the wetness in the bell housing is pb blaster that i tried to get inside of it to loosen it up
Old October 23rd, 2011, 10:30 AM   #86
Renegade II
Coil springs are for pens
Renegade II's Avatar
With that trans (or any non OD,) 4th gear will still be 1:1 and not effect top speed. With that or a T18, T19 etc... you just gain the granny geared 1st to obtain higher mechanical leverage for difficult low speed obstacles.
The flywheel has some heat spots on it, get it ground. That said, you don't just do one part of a clutch job.
Don't worry about the shackels until you get to tearing apart the suspension.
I'd never go less than 4:10's with 35's & an I4 engine.
Old October 23rd, 2011, 12:11 PM   #87
reptile610
reptile610's Avatar
i talked to somebody and they mentioned trying to find a 5 spd for the highway. but i figured 4.56 with 35's atleast. going to pick up the new clutch, throw out bearing, 4 new u joints and then swinging by jeepinz for the brake booster today.
Old October 24th, 2011, 09:32 AM   #88
reptile610
reptile610's Avatar
Got a new clutch kit, 4 new u joints, and gear lube. Getting fly wheel resurfaced then ill need help installing all this =]
Old October 24th, 2011, 03:58 PM   #89
Wramblerguy
Wramblerguy's Avatar
dont waste your time with a 5 speed unless you gear low im running a mpi 4 cylinder with 150 thousand miles 4:10 gears and 31s and i cant pull 5th gear on the highway
and you want to run bigger tires with a motor with less power then mine so if you stay with the i4 i would suggest at least 4:88s
Old October 24th, 2011, 09:38 PM   #90
reptile610
reptile610's Avatar
yes but i wanna upgrade to an amc V8
Old October 24th, 2011, 10:04 PM   #91
jeepinjz
jeepinjz's Avatar
Get your wallet out LOL I have the axles and motor you need would take care of your needs fuel injected AMC v-8 and axles with 4:88's in them already cheap.Thanks for the purchase on the booster also.
jeepinjz is offline   Reply With Quote
Old October 25th, 2011, 04:15 PM   #92
reptile610
reptile610's Avatar
u have the dana 30 and amc 20 axles though right? i don't want those =p want 44's lol. but maye the v8 though it'll be awhile for me to get that money up
Old October 26th, 2011, 03:48 PM   #93
Wramblerguy
i know you do but u said u wont have a v8 for a while so im saying dont waste your money on a 5 speed while you still have the 4 banger
Old October 27th, 2011, 07:45 PM   #94
reptile610
reptile610's Avatar
oh, yeah agreed.
Old October 30th, 2011, 10:40 AM   #95
reptile610
reptile610's Avatar
ok so i was looking up stuff to redo the wiring in the jeep. i was looking for a replacement for a complete rewiring kit is this it?
http://www.quadratec.com/products/17015_00.htm
if so it doesn't say anything about engine type so im guessing it wouldn't matter? the wiring is completely destroyed in this thing and nothing electrical works.
Old October 30th, 2011, 10:46 AM   #96
reptile610
reptile610's Avatar
also just found this
http://www.quadratec.com/products/17016_00.htm
Old November 17th, 2011, 05:43 PM   #97
reptile610
reptile610's Avatar
update: put 3 coats of rust reformer on the underbody, then did 5 coats of rustoleum undercoating on it. this weekend im going to remove the broken bolts from the frame and take the flywheel in to be resurfaced.
Old November 26th, 2011, 07:03 PM   #98
reptile610
reptile610's Avatar
chuck (hamsmotorsports) is coming over tomorrow to give me a hand putting the jeep back together. should be able to drive it on the jack stands tomorrow afternoon =]
Old November 27th, 2011, 01:02 PM   #99
reptile610
reptile610's Avatar
thanks for all the help chuck, now i know how to change a clutch and u-joints =]
Old December 4th, 2011, 07:34 PM   #100
reptile610
reptile610's Avatar
everything is all put back together except for the crossmember, also today i bought 4 full doors, a hard top w/ extra lift gate, and a bikini top from goofy for $300.
Page generated in 2.01579 seconds with 83 queries
