4L80E Trans Problems! HELP!!!! shifitng too soon - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 7th, 2011, 10:52 PM   #1
BigBlockJimmy
Default 4L80E Trans Problems! HELP!!!! shifitng too soon
i have a 4l80e trans in my 96 2500 4x4 suburban, the trans shifts into overdrive someitmes from first gear, then when you let off the gas and get into the gas harder it will shift back into first and shift normal if you floor the gas pedal!, other times the truck shifts perfectly normal, also i can manualy shift the trans with the shifter on the column and it shifts perfect, no slipping or hard shifts, PLEASE HELP!!! this is so annoying!
BigBlockJimmy is offline   Reply With Quote
Old August 8th, 2011, 07:11 AM   #2
jeepbrattt
New car smell.....Mmmmmmm
Mine did the same thing. I was told 4l80's are known for that. I had tranny tom put a shift kit in mine. Holds first just fine now.
jeepbrattt is offline   Reply With Quote
Old August 8th, 2011, 07:45 AM   #3
TopGunn
Burried
TopGunn's Avatar
Send a message via AIM to TopGunn Send a message via MSN to TopGunn
Thats because the 60l and 80l are pos transmissions. Ive been threw multiple 80's in my plow truck.
TopGunn is offline   Reply With Quote
Old August 8th, 2011, 07:51 AM   #4
jeepbrattt
I've heard they are a pain in the ass because of the electronics, but never heard a single person say they are a pos before. Usually hear quite the opposite, that they are quite bulletproof.
Liking mine just fine right now.
Old August 8th, 2011, 09:30 AM   #5
RADRICK
RADRICK's Avatar
I think the 4l80 is actually pretty stout,the only thing I've seen common with 80's is the reverse band going out, usually in plow trucks.
Old August 9th, 2011, 03:28 PM   #6
BigBlockJimmy
thanks alot guys! and jeep bratt i thank you again for the PM i got ahold of tom and he told me to birng it to him and scan the truck to see if its throwing any codes, hes saying it sounds electronic, im hoping i can get this solved before silver lake sand dunes!!!
Page generated in 0.22000 seconds with 41 queries
