Inner Air Lock Bead Locks and Wheels - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 5th, 2011, 09:59 PM   #1
Dana60CJ
Dana60CJ's Avatar
Default Inner Air Lock Bead Locks and Wheels
4 Inner Air Lock bead locks for any 15 x 7-10 inch wheel. The wheels pictured are 15 x 8 with a 5 on 5.5 bolt pattern, have been drilled to install the bead locks, and are included if you want them. They pneumatically lock both tire beads allowing the tire to run extremely low pressures off road. I have run as as low as 3 psi with great results, and they're a lot lighter than bead lock wheels. They inflate an inner tube inside a casing that puts all 30 psi on the beads while leaving the tire psi up to you.
I used this set only 2 years and all the hardware, 4 inner tubes and 4 casings are included along with the wheels.
Here is the companies website for more information.
http://www.innerairlock.com/
Pictures are here http://lascruces.en.craigslist.org/pts/2525621759.html
$400 + shipping
Chris
575-652-2162
Las Cruces, New Mexico
Dana60CJ is offline   Reply With Quote
Page generated in 0.56345 seconds with 26 queries
