next greatest sport! - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Pictures and Video
Pictures and Video A forum for 4x4 related photos and videos
Old August 5th, 2011, 09:23 AM   #1
Blakemore00XJ
Blakemore00XJ's Avatar
Default next greatest sport!
women's motocross
Blakemore00XJ is offline   Reply With Quote
Old August 5th, 2011, 09:27 AM   #2
Andy456123
Guest
Andy456123 is offline   Reply With Quote
Old August 5th, 2011, 09:40 AM   #3
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
The one going down in the water as the checker flag is being taken.
Old August 5th, 2011, 10:01 AM   #4
Old August 5th, 2011, 10:12 AM   #5
Toivo
Feel lucky?
Toivo's Avatar
thats funny. pretty gnarly track too!
Old August 5th, 2011, 10:31 AM   #6
All5ofus
All5ofus's Avatar
Holy cow that was funny and sad at the same time . . . . GIRL POWER! No you can NOT do anything a guy can do better.
All5ofus is offline   Reply With Quote
Old August 5th, 2011, 10:54 AM   #7
gmcpower98
Geocacher!!!!!!!!!!
gmcpower98's Avatar
Saw that on T.V..........fun to watch!
The guys rocked that course!
My first thought was widen it out a bit, and run Jeeps on it!
Minus the starting hill
gmcpower98 is online now   Reply With Quote
Old August 5th, 2011, 11:18 AM   #8
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
Old August 5th, 2011, 11:19 AM   #9
Christmas Cookie
and those are 2-wheel drive MX bikes
Old August 5th, 2011, 11:22 AM   #10
GMKLR50
Broke wheeler
GMKLR50's Avatar
this racing is cool with the guys and totally funny with the girls....I like this kind of racing cause its more like what you would find in the real world but amped up for the pros and stuffed in to a short course for TV.
GMKLR50 is offline   Reply With Quote
Old August 5th, 2011, 11:44 AM   #11
Blakemore00XJ
Originally Posted by High Center Hancho View Post
Never understood what the grill ment?
Old August 5th, 2011, 12:11 PM   #12
nickb304
nickb304's Avatar
They had and enduro x section at the last harescramble i raced. It was fun. easy to make up time on guys when your are over 6ft tall.
nickb304 is offline   Reply With Quote
Old August 5th, 2011, 12:37 PM   #13
Flexin' XJ
Flexin' XJ's Avatar
r e p o s t
Flexin' XJ is offline   Reply With Quote
Old August 5th, 2011, 12:39 PM   #14
gmcpower98
Geocacher!!!!!!!!!!
gmcpower98's Avatar
Are you sure?
I looked at the video several times and looked at this:
http://espn.go.com/action/xgames/sum...enduro-x-debut
Saw rear tire spin not front.
Not sayin' your wrong but, just sayin' I dont see it.
Old August 5th, 2011, 12:42 PM   #15
extremajoe
the man,myth,legend
extremajoe's Avatar
I love the chick at the end of the race, taking a bath in the water pit!
extremajoe is offline   Reply With Quote
Old August 5th, 2011, 12:44 PM   #16
ouchman
ouchman's Avatar
Send a message via Yahoo to ouchman Send a message via Skype™ to ouchman
Not all of them.
support the sport- www.GLFWDA.org - member
Dear Travelers,
You won't see London and you won't see France, until we see your underpants!
Sincerely, TSA Officers
ouchman is offline   Reply With Quote
Old August 5th, 2011, 12:48 PM   #17
Christmas Cookie
in that sport they are
http://www.christini.com/awd-technology.php
Old August 5th, 2011, 12:55 PM   #18
jeepinRRT
jeepinRRT's Avatar
Nope, they're not. Some, yes. All, no.
jeepinRRT is offline   Reply With Quote
Old August 5th, 2011, 01:01 PM   #19
Christmas Cookie
no all of them...just ask mr green...
Old August 5th, 2011, 01:02 PM   #20
gmcpower98
Geocacher!!!!!!!!!!
gmcpower98's Avatar
Sounds complicated but cool how it works.
Quote from the FAQ section on the site:
See how this works in our AWD Technology section.
The power is passed through a series of gears, chains and shafts.
•Step 1. We utilize a special double sprocket mounted directly to the countershaft of the motor. The inside sprocket sends power to the rear wheel just like on your everyday motorcycle. The outer sprocket sends power via a standard 420 roller chain up to a gear box mounted on the frame under the tank.
•Step 2. The right angle gearbox is mounted to the modified frame and hides under the custom gas tank. The input of the gear box is from the secondary chain and the power leaves the gearbox through a shaft leading to the custom head tube. The gear box also houses the engagement switch. The engagement/disengagement is handled by a spring loaded spline which allows you to turn the system on and off with the flip of a switch.
•Step 3. Inside the customized head tube is where things really start to happen. The main drive shaft ends inside the tube at a bevel gear. The bevel gear drives two concentric counter-rotating shafts that transfer power down to small sprockets that are housed inside our special 2 piece bottom triple clamp.
•Step 4. Inside the bottom triple clamp we have two small counter rotating sprockets that are centered along the head tube axis. A small chain runs from each sprocket to small sprockets built into the fork drive shafts.
•Step 5. The specially coated drive shafts are telescopic allowing the suspension to travel freely. They incorporate recirculating linear ball spline bearings. These bearings allow for the patented translation of the power, and eliminate stiction of the suspension when loaded under power. The drive shafts are counter rotating to eliminate any adverse torque effect when the power is applied to the front wheel. They run the length of the fork to the front hub.
•Step 6. Inside the modified fork dropouts, the lower fork drive shaft transfers power 90 degrees via a bevel and pinion gear set. The power is transferred to the hub drive system where a one way sprag bearing allows for the transmission of power when it is needed and allows the front wheel spin freely when there is traction available at the rear wheel.
Page generated in 0.50231 seconds with 83 queries
