Samurai third member swap HELP! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 4th, 2011, 08:49 PM   #1
sleeperd2
sleeperd2's Avatar
Default Samurai third member swap HELP!
OK i bought a samurai off here a while ago and seen you can take 2 front third members from a auto or manual tracker.Got a third member from a manual tracker and my axles are to big to just slide into carrier. What does this swap consist off? Does any year tracker work?
sleeperd2 is offline   Reply With Quote
Old August 4th, 2011, 10:39 PM   #2
scottie
Eye candy
scottie's Avatar
Any year from 89-98 should work.
Look on Zuwharrie.com for more information, i think you'll have to swap the side gears.
Old August 5th, 2011, 12:35 AM   #3
stuckinthemud
stuckinthemud's Avatar
the front will work in the front from 89 to 95 or 96 then rear is 98 an newer you need i think
stuckinthemud is offline   Reply With Quote
Old August 5th, 2011, 06:43 AM   #4
jimmyroyse
webwheeler
jimmyroyse's Avatar
Scottie has it. you need to swap the side gears in the rear chunk.
jimmyroyse is offline   Reply With Quote
Old August 5th, 2011, 09:20 AM   #5
sleeperd2
sleeperd2's Avatar
OK thanks guys
Old September 8th, 2011, 11:59 AM   #6
orionn
orionn's Avatar
Just to compile the info here, and add a little:
Front tracker thirds fit in the samurai axles.
Used in the front, they bolt in.
Used in the rear, you swap in your samurai side gears first.
In the front the aluminum third member will hold up prety well, but the rear should have the gears swapped to the Samurai steel third member.
Besides, the Samurai carrier is a 4 pin carrier (stronger). you will need to add a shim to the ring gear and a aftermarket retainer ring for the cross pins (or tack weld the cross pins in place)
Remember, only the Tracker front thirds and gears fit the samurai axle housings.
Its prety simple really.
hope that clears it up for you.
orionn is offline   Reply With Quote
Old September 8th, 2011, 03:23 PM   #7
sleeperd2
sleeperd2's Avatar
Cool thanks for help guys
Page generated in 0.15777 seconds with 44 queries
