**HELP ASAP**727 valve body removal - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 4th, 2011, 02:42 PM   #1
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
Send a message via AIM to dakotaguy1
Default **HELP ASAP**727 valve body removal
I have to replace the seal where the shifter go's into the trans, and was told i have t drop the valve body. Any tips or advice that will help?
dakotaguy1 is offline   Reply With Quote
Old August 5th, 2011, 11:36 PM   #2
TsCuda
TsCuda's Avatar
Dont drop it. You'll lose the check balls. Remove the pan, the filter, and the bolts that hold the vb in. real easy.no tricks.
TsCuda is offline   Reply With Quote
Old August 6th, 2011, 02:18 PM   #3
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
Well i need help asap everything was going good then this ball and spring flew out im thinking it gos where the spring is now???? any help would be great.
Old August 6th, 2011, 02:55 PM   #4
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
That's the ball dtent. Goes to the rooster comb. It locks the gear selector in place....you are correct it goes on the spring. Spring just keeps pressure on the ball to require force to move. Sry if I can't type. Im on the shitter and phone
Old August 6th, 2011, 04:08 PM   #5
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
Hahaha thanks for your efforts yeah i was able to find this diagram that helped (same thing you said).
http://www.amccf.com/tech/AT/AT_TF72...e_assembly.jpg
Old August 6th, 2011, 07:26 PM   #6
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
Alright i got a new problem got it allback together and when i go to put it in park it still rolls. Any idea what the problem could be? It doesnt have fluid in it yet that wouldnt be the problem would it?
Old August 6th, 2011, 08:32 PM   #7
GREASYHANDS
GREASYHANDS's Avatar
Sounds like the roster comb is misadjusted anf its not fully in park. Did you clean all that grit off before you reassrmbled the valve body? I
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old August 6th, 2011, 08:44 PM   #8
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
prolly a dumb question but how can it be mis adjusted? and yeah i cleaned it off
Old August 6th, 2011, 08:55 PM   #9
GREASYHANDS
I would assume it has a rod type linkage from the column to the trans. If you took the seal out you would have had to remove the linkage and disturb the proper range of movement, right? Try disconecting the linkage nearest the trans and moving it into park by hand.
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old August 6th, 2011, 08:57 PM   #10
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
It has a b&m shifter on it and i did disconnect it and put it in park and it still rolled. on my next off day im gona pull it apart again and see if anything is disconnected or something, just wondering what specifically to look for.
Page generated in 0.29005 seconds with 53 queries
