Sold* 99 TJ on 33's - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 4th, 2011, 10:48 AM   #1
Bustabizz
Default Sold* 99 TJ on 33's
4 cyl, Auto, 127k on it. $2800 obo. Send me a PM.
The good:
Runs great, shifts great, really good oil pressure for 127k miles, 40 idle, 60 driving. Optima Red Top. Half Top is in decent shape (needs a Tonneau Prop), I also have Factory Hardware for a full soft top. 2-Piece Soft doors in decent shape. Seats are in good shape, has a Tuffy Console. Has heavy duty front and rear bumpers, and front Warn Winch mount, and Poison Spyder Tube fenders. 3" 4WD Hardware Lift. JKS Disconnects. Within the last 2 years it has had the radiator replaced, hub bearings, tie rod ends, and ball joints. Brakes are good too, I think they were done like 2-3 years ago. Has only like 20k miles on it since then. Has AT tires on it with 50% tread. Will make a great project vehicle.
Not so good:
It leaks oil, looks like out of the valve cover gasket, but like I said real good oil pressure. The idle air control is dirty I think and needs cleaned, it runs rough at first when started and hard starts, but once it goes it runs great. The rust on the back by the tailgate is ugly but I will include Poison spyder corner guards that will cover it. The one middle body mount is rusted through on the tub, but the rest of tub and frame are in fairly good shape. It has an exhaust leak. The middle panel on the dash is busted from when someone broke into it, simple fix. It does not have fender flares.
It doesn't have a winch on it anymore. The Warn Winch mount is still on it. Has AT tires on it now.
Pic is 2 years old.
Bustabizz is offline
Page generated in 0.20146 seconds with 26 queries
