Front pinion angle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old August 2nd, 2011, 08:33 PM   #1
dakotaguy1
DODGE POWER!
dakotaguy1's Avatar
Send a message via AIM to dakotaguy1
Default Front pinion angle
I need to know what degree shims are normally on a 6" front leaf spring for a 83 dodge ram. thanks
dakotaguy1 is offline   Reply With Quote
Old September 2nd, 2011, 04:06 PM   #2
chriszildjian17
chriszildjian17's Avatar
that all depends on your pinion angle and your caster angle. If you mesure those. you can determin what shim you need. There is no normal shim. every truck is a little bit different as far as pinion angle, and alignment mesurements.. I have never seen or heard of more than 1 truck ever have the same mesurement.
chriszildjian17 is offline   Reply With Quote
Old November 20th, 2011, 08:03 PM   #3
snocross2xtremes
snocross2xtremes's Avatar
your gonna want to set your caster to -6. and your pinion angel is gonna be what it is. if you have issues your best option would be to spin the knuckles.
Old November 23rd, 2011, 06:09 PM   #4
Ollywood
Ollywood's Avatar
Send a message via Yahoo to Ollywood
I'm in the middle of swapping over to 60s on my 78 Ramcharger. I want to kill the vibrations I had with the 44F and 9 1/4 rr. I have a BDS 5" lift.
Does spinning the knuckles create any problems for anything else?
Would that be the same idea as spinning the perches on the rear?
Would it be better to run without shims?
Thanks
Ollywood is offline   Reply With Quote
Old November 23rd, 2011, 06:20 PM   #5
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
If it was me I would set my caster angle with shims and if I still ended up with vibrations I would then grind the welds of the knuckles, spin and reweld to change my pinion angle. Just my .02...
Old November 23rd, 2011, 06:34 PM   #6
Ollywood
Ollywood's Avatar
Just dont wanna end up having to get 2 front driveshafts made thats all
Old November 23rd, 2011, 06:43 PM   #7
chadcooper55
Rotating the pinion angle a few degrees doesn't seem like it would change your drive shaft length enough to make it no longer work.
Old November 29th, 2011, 03:28 PM   #8
Ollywood
Ollywood's Avatar
I hope not. Would you bother keeping the shims if you spin the knuckles?
Old December 5th, 2011, 09:53 AM   #9
PavementPounder
PavementPounder's Avatar
Thanks
Absolutely. They should not be used on a front axle that was not designed that way from the factory.
If your caster is fine, drill out the plug welds on the diff housing at the tubes, rotate the pinion up, and re-weld.
Old December 5th, 2011, 02:58 PM   #10
Ollywood
Ollywood's Avatar
Your referring drilling out the plugs on the front axle?
I like your theory on shims. You suggest getting rid of the shims on the rear axle as well?
Old December 5th, 2011, 03:17 PM   #11
PavementPounder
It isn't a theory. It is sense, in addition to Michigan State Law. Installing shims in a front suspension that did not come with them is a procedure initially concieved as a band-aid by the OEMs so that they could address issues with vehicles which they were responsible for, yet did not want to pay for due to cost. If you think about it, aside from owner modifications there is no reason for a vehicle to not have factory-spec caster unless it has been damaged or somehow assembled in error (weld fixture f'd up, parts bent due to operator error/drunk forklift driver, etc). The latter would be something claimable against warranty. If you were the OEM, would you want to replace an entire vehicle frame or axle assembly if a $5 shim could give the customer satisfaction? This is how the unsafe practice of creating a clamped assembly stack in a steering axle which can do nothing but slowly wear away material over time and loosen was born and became popular. Putting a shim in there really isn't different than a lift block. They are just differing levels of severity.
Rear shims are less of an issue due to the different nature of the forces and power acting on them, but the ideal arrangement would be to rotate the perches.
Old December 5th, 2011, 03:23 PM   #12
Ollywood
Ollywood's Avatar
Thanks PavementPounder for the info.
Page generated in 3.34138 seconds with 59 queries
