SBC Chevy 350 Parts - $75 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 31st, 2011, 06:15 PM   #1
JeepManHuff
Muddin is Livin
JeepManHuff's Avatar
Default SBC Chevy 350 Parts - $75
I have a small block 350 Chevy for sale. It is a 2 bolt main block and the cylinders appear in very good condition just need a light honing. Engine is out of an early 70s full size Chevy truck and ran great shortly before pulled. Engine suffered a spun main bearing so the crank does have a couple rough journals - They don't seem too bad, may just be good with a polishing, but better to be safe than sorry in having the crank ground. It is basically a long block engine (intake, carb, distributor, and accessory drive are all missing).
Definitely a great start point for a good running engine. Asking $75 for it. If interested, my number is (517) 489-6927, texting is the best way to get ahold of me.
Last edited by JeepManHuff; July 31st, 2011 at 06:16 PM. Reason: no pictures posted
JeepManHuff is offline   Reply With Quote
Old July 31st, 2011, 06:27 PM   #2
JeepManHuff
Muddin is Livin
Pics of the engine
ID:	81734   Click image for larger version
ID:	81735   Click image for larger version
ID:	81736   Click image for larger version
Old July 31st, 2011, 09:24 PM   #3
trailhogg
do you know the exact year
trailhogg is offline   Reply With Quote
Old August 1st, 2011, 12:21 AM   #4
JeepManHuff
Muddin is Livin
No I don't. It was out of a buddy's 77 Chevy 3/4 ton. Bought it from him with plans of building a backup V8 for my S10, but that plan fell thru bc i need the cash. I can upload a pic of the casting numbers tho if that helps
Old August 1st, 2011, 06:08 AM   #5
stroker00s10
Odd Man out with a S10
stroker00s10's Avatar
I'll give ya a hundred for it all if you hold it for me till friday when I get paid . txt 810 410 6600
stroker00s10 is offline   Reply With Quote
Old August 7th, 2011, 09:36 PM   #6
JeepManHuff
Muddin is Livin
350 & parts are all still available btw.
And also for those interested I also have an AutoMeter 3-3/8" Z-series tachometer. Can be set to 4-, 6-, or 8-cylinder engine configurations and has an 8,000 RPM redline. Still in factory packaging only been out of the box a couple of times. Never has been used on a vehicle. Also have a mounting cup and flat surface mount, no hardware to mount it tho. Paid $120 for the tachometer and another $15 for the mount from SummitRacing. The first $110 can have the tachometer and cup. The first $175 can take it all
Name:	Z series.jpg
Old August 9th, 2011, 08:55 PM   #7
trailhogg
ill still take it 5862562809
Old August 14th, 2011, 06:11 PM   #8
JeepManHuff
Muddin is Livin
350 Block and parts is sold. The Autometer Z-Series tachometer is still available tho.
Page generated in 0.39626 seconds with 48 queries
