4.0,aw4,231---found--- - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 31st, 2011, 01:26 PM   #1
hghgrad
hghgrad's Avatar
Default 4.0,aw4,231---found---
Starting to look for a swap for my wrangler. I'm going to be tearing out the tragic 4cyl auto combo over the fall/winter and want to swap a basic cherokee drive line in.
I'd like to pick everything up as a package if possible.
Prefer as close to Monroe mi, 48161...
hghgrad is offline
Old July 31st, 2011, 06:00 PM   #2
Jleach0696
Jleach0696's Avatar
what years do you care if it is HO or renix
Jleach0696 is offline
Old July 31st, 2011, 07:38 PM   #3
hghgrad
hghgrad's Avatar
I'd prefer ho to keep from doing a bunch of wiring.
hghgrad is offline
Old August 2nd, 2011, 10:48 AM   #4
hghgrad
hghgrad's Avatar
Bump
hghgrad is offline
Old August 3rd, 2011, 06:29 AM   #5
martianjeep
too broke to wheel
martianjeep's Avatar
I have a aw4 out of a 97 xj that just needs a front pumpseal if youre interested.
martianjeep is offline
Old August 3rd, 2011, 05:11 PM   #6
special k
special k's Avatar
i have a 4.0L from a 97 xj
special k is offline
Old August 6th, 2011, 01:21 PM   #7
hghgrad
hghgrad's Avatar
Still looking...
I'd also consider an ax15 instead of the aw4. My old lady hates the jeep anyways, so I don't really have to worry about teaching her to drive a stick.
hghgrad is offline
Old August 6th, 2011, 08:02 PM   #8
little_yj_95
little_yj_95's Avatar
I'm getting ready to pull the motor,trans and transfer case out of my 95 yj. Motor runs strong but the block has a crack that I jb welded up. No leaks and does not over heat. Ax15 trans,231 transfer case with a wider Cain kit in it and a slip yoke eliminator kit. Pulling it to v8 it and use my atlas.
little_yj_95 is offline
Old August 14th, 2011, 01:19 PM   #9
hghgrad
hghgrad's Avatar
Picked it up yesterday. Lock it up
hghgrad is offline
Page generated in 0.28223 seconds with 50 queries
