95 F150 rear brake line fitting size? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 29th, 2011, 04:49 PM   #1
chevyk10
FORD / GM
chevyk10's Avatar
Default 95 F150 rear brake line fitting size?
The brake line that leads to my passenger side rear tire just blew out right before the fitting. Would like to replace it tonight by does anyone know what the fitting size is for that line?
chevyk10 is offline   Reply With Quote
Old July 29th, 2011, 07:43 PM   #2
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Should be 3/16 inverted flare.
Old August 1st, 2011, 01:26 AM   #3
chevyk10
FORD / GM
chevyk10's Avatar
thanks, it was 3/16".
Page generated in 0.25693 seconds with 32 queries
