95 Sierra - Won't turn over - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 28th, 2011, 06:40 PM   #1
95GMC
Default 95 Sierra - Won't turn over
Hi, I have a 1995 Sierra 5.0l 4x4. I just bought it yesterday. I actually went to see it twice before I even picked it up. So that's 3 times that I've successfully started it up with no issues. It does have a new alternator, that's about it for under the hood. I parked it in my drive last night to get to it today. I was going to move it today, but it did not turn over. There are no leaks on this truck. Also, it did rain heavily last night, with severe lightning. I tested the battery, it is fine.
What could have gone wrong? What should I test first? I hope this is only faulty wiring..
Thanks,
~Garrett
95GMC is offline   Reply With Quote
Old July 28th, 2011, 06:52 PM   #2
deerebowtie
Unchained
deerebowtie's Avatar
do you know how to google? I suggest you learn.
if you're truly helpless and need to learn to troubleshoot a system, ask for help with an offer of beer & pizza or something along those lines.
Old July 28th, 2011, 08:57 PM   #3
95GMC
This IS Chevy Tech, and I am asking a question in it. Google can give you anything. What kind of dumbass reply is that. People with EXPERIENCE (I'm guessing you lack) can tell you firsthand what might be wrong. Grow up.
Anyways, I found that it is the starter that went. What type of starter would you suggest? I would only need the solenoid, not including the pinion gear or mounting bracket.
Old July 28th, 2011, 09:06 PM   #4
deerebowtie
Unchained
any starter from a chevy V8 non LS series. They're all the same thing. mix and match parts from the starter if you get one of the older ones with the 3 bolt nose cone from a muncie.
your issue is easily traced was my point. if you have power in the cab, and not at the starter, its either a fuse, loose/shorted wire, or dead solenoid.
Old July 28th, 2011, 09:07 PM   #5
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
get a mini starter from a newer s-10 4.3 Smaller and easier to change with good durabibity.
Old July 28th, 2011, 09:07 PM   #6
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
Just get whatever autoparts store has with the best warranty available.
Old July 28th, 2011, 09:08 PM   #7
ChevyRacer1981
or that^^^
Old July 28th, 2011, 09:10 PM   #8
osteologation
Deerbowtie's answer would seem more appropriate in the pub then tech. He was just asking a question. Not everybody has a lot of troubleshooting experience. Hence the reason for tech forums.
Old July 28th, 2011, 09:15 PM   #9
95GMC
Yeah sorry I took that the wrong way. I went to Autozone and they told me $135 for a replacement. I'm not sure if they sell the solenoid alone or not.. If not, I'll be going with this: http://www.summitracing.com/parts/SUM-829000-S/
Thank You one and all.
Old July 28th, 2011, 09:19 PM   #10
osteologation
I just checked autozone and it's 89.99 for lifetime and 74.99 fir 1year warranty.
Old July 28th, 2011, 09:20 PM   #11
osteologation
Seems pricy to me, you check rockauto.com?
Old July 28th, 2011, 09:24 PM   #12
osteologation
http://www.rockauto.com/catalog/x,ca...,parttype,4188
Old July 31st, 2011, 07:17 PM   #13
95GMC
No replacements necessary - Wires were loose
Page generated in 0.32436 seconds with 62 queries
