car hauler tires wearing on the outside edges - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 28th, 2011, 02:34 PM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default car hauler tires wearing on the outside edges
I pull with a f350 dually so I put a lot of the weight on the tongue. I have the tires aired up to their max 50psi and researching indicates outside worn edges are an under inflated tire.
Both sides and both axles have the same wear. They are Bias ply tires but I'd assume that would not matter???
Anyone else have this same issue or am I just always loading it up wrong? It pulls great with no swaying.
Old July 28th, 2011, 02:47 PM   #2
tweak
Are we there yet?
tweak's Avatar
Are you using LT or ST tires?
Old July 28th, 2011, 02:52 PM   #3
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
X 2 on the type of tire. If you are loading it that heavy- get a set of load range "E" or "LT" tires.
On the other hand- from turning (especially with a tripple) you do wear the outside edges of the tires 1st.
Old July 28th, 2011, 03:55 PM   #4
bigyj
bigyj's Avatar
Mine do that also. I assumed its from turning alot. Watch your axles pivot when you turn, lots of side drag on those trailer tires.
bigyj is offline   Reply With Quote
Old July 28th, 2011, 05:10 PM   #5
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Ah turning makes sense. They are load range C.. which came with trailer when bought new. .... seems tires are wring. Sticker on front say range d and lists the specs.
Old July 28th, 2011, 08:01 PM   #6
tweak
Are we there yet?
tweak's Avatar
Load range C sounds pretty crappy... What is the weight spec's on the tires? I would go to a D range tire.
I got a set of Goodyear ST's for my car hauler... They are the more HD ST tire, and ST tires are built to have less side wear.
Old July 28th, 2011, 09:20 PM   #7
84Scrambler
If this is a single car hauler, load range E tires are overkill. I use them on my 37' gooseneck that is rated for 20,000 pounds. You should have D's though.
Old July 28th, 2011, 09:30 PM   #8
scottie
Eye candy
scottie's Avatar
is it just the front set of tires or the rear too?
Old July 29th, 2011, 11:48 AM   #9
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Should be d as sticker states that....I need to replace soon so ill get d. They wear on both axles.
Page generated in 0.18998 seconds with 50 queries
