New Product: Ford 8.8" C-clip Eliminator Kit with 31-Spline 4340 Axles - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old July 28th, 2011, 10:20 AM   #1
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Default New Product: Ford 8.8" C-clip Eliminator Kit with 31-Spline 4340 Axles
ULTIMATE 88 axle kit 95-02 Explorer, 4340 CHROME-MOLY ( DOUBLE DRILLED). The Yukon Ultimate 88 kit eliminates the factory c-clips and converts your housing to use two 4340 Chrome-Moly bolt in axles. No welding is needed, just a little cutting to remove the factory axle bearing seat. The result is a super strong setup to give you years of hard use on the trail!
These fit 1995-2002 Explorer 8.8 rear axle housings and feature:
  • C-clip eliminator system using Timken Set-20 bearings
  • Double drilled 4340 axles, 31-spline (5x5.5 and 5x4.5)
  • They increase the track width of the Explorer housing 1-inch per side. (Explorer’s are 1.75” narrower than a Jeep YJ/TJ/XJ housing)
  • No welding (cutting is involved on the housing)
  • Screw in studs (studs supplied, ½-20 sized)
  • Fits with factory disc brake assemblies
$508.95
Ultimate 8.8" Axle Kit
Jeeperz Creeperz, Inc.
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
www.jeeperz-creeperz.com
Old August 3rd, 2011, 05:46 PM   #2
itchy
itchy's Avatar
Me likey........
itchy is offline   Reply With Quote
Old August 6th, 2011, 11:57 AM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Originally Posted by itchy View Post
Me likey........
Wanna bring that axle back?
1627 Eureka Rd
Wyandotte, MI 48192
734-281-8141
M-F 10am-7pm
Sat 10am-3pm
Tags
c-clip eliminator, ford 8.8
Thread Tools
Page generated in 0.25831 seconds with 32 queries
