Dodge Cummins 2500 4WD Sport ECLB - 98 24V Very Clean - All Upgrades - SOLD - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 28th, 2011, 10:21 AM   #1
jakegp
WFW
jakegp's Avatar
Default Dodge Cummins 2500 4WD Sport ECLB - 98 24V Very Clean - All Upgrades - SOLD
***New pics added Aug. 3
Selling my Jeep and don't need the tow rig anymore.
Make: Dodge
Model: Ram 2500 Sport 4X4
Style: Ex Cab Long Bed
Year: 1998.5
Engine: Cummins 24V Diesel
Mileage: 192K on truck -- 60K on motor (installed by Cummins under warranty)
Options: Leather, All Power, Thermometer/Compass, Rear Slider, Power/Heated Mirrors, etc...
Very clean truck with many options and upgrades. Well maintained and serviced. All weak points have been addressed from the fuel system to the transmission to the front end.
$5,000 in maintenance and improvements have been completed in the last 5K miles
Adult owned and well maintained.
Truck spent 99% of its life in KY and has not been subject to bad conditions.
Truck was Ziebart treated when new which has helped to keep the body clean.
Runs strong and everything works.
Ready to fuel and go.
Body:
- Very clean and straight
- Debaged
- Rhino Lined bed
- HID headlight upgrade with crystal housings
- IPF driving lights
- Color matched front brush guard
- Stainless rear tail light guards
- Tinted Windows
- Sliding rear window
- Aluminum bed rail caps
- Stainless nerf steps
Interior:
- Very clean (no tears, stains, etc. . .dash is perfect)
- Tan leather
- Husky floor liners
- Clarion CD player with integrated ipod control (new May 2011)
- Clarion EQ
- Sirius Satellite radio
- Punch 10" in shadow box (hidden under center bench seat)
- Punch amp
- Brake controller
Transmission: Fully rebuilt and upgraded
- ATS triple disk billet torque converter
- DTT 300M input shaft
- DTT Valve body & Shift Kit
- Billet servo
- Billet accumulator
- BD Pressure lock
- MAG Hytec pan (trans and rear axle)
- Serviced with newAmsoil fluid and filter ~ 2K miles ago
- DTT signal filter (ensures proper lock up)
Engine: (53 block replaced by Cummins under warranty ~ 60K miles ago)
- Stock internals
- Formula 1: Mach 2.2 injectors
- Edge tuning box
- BHAF in AFE cold air box
Fuel System: (maintains 15+ psi during all conditions)
- Blue Chip Diesel VP 44 injection pump (has less than 5K miles - $1650)
- Carter pusher pump on frame rail (redundant lift pump)
- Upgraded fuel lines (larger size braided stainless)
Gauges: (all AutoMeter silver faced Ultralight gauges)
- A pillar
o Fuel Pressure
o Pyrometer
o Boost
- Transmission Temp (in steering column pod)
- UltraGauge digital data center (engine load, fuel mileage, throttle, code reader,etc. . .)
- Blue Chip Diesel fuel pressure light
Exhaust:
- 5" all the way out
- Magnaflow muffler
- 6" stainless tip
Suspension:
- DT Pro-Fab leveling kit
- DT Pro-Fab control arms
- DT Pro-Fab aluminum track bar (less than 1K miles)
- Bilstein shocks on all 4 corners
Steering: (all steering components replaced in last 2K miles)
- DT Pro-Fab steering brace with box support
- Thuren: Fox Steering Stabilizer
- Moog drag link, tie rod and rod ends (replaced 2K miles ago)
Wheels & Tires:
- Alcoa forged wheels
- BFG 315 all terrain tires (less than 2K miles)
Misc:
- 4.10 axle gears
- B&W turnover ball in bed (never used)
- Aluminum tool box in bed
- Yakima roof rack
- MAG Hytec rear differential cover
- Dana 70 rear axle
Maintenance: all items completed in last 2K miles
- Batteries (2) -- replaced in May 2011
- Front Axle ($2,300 in work)
o New unit bearings (Federal Mogul premium parts)
o New rotors
o New calipers
o New brake pads
o New u-joints
o New ball joints (Moog)
o New tie rod
o New drag link
o New Fluid
- Fuel filter
- Air filter
- Transmission fluid and filter (Amsoil)
- Transfer case fluid
- Front driveshaft u-joints
- Rear axle fluid
- Alternator
- Starter
- Heat Grid solenoid
- Multi-Function Switch (headlight, wipers, etc..)
- Alignment
- Tires
- Injection pump (Blue Chip Diesel) -- 5K miles
- Lift pump -- 5K miles
I'm sure there is a lot that I am missing. This is a great truck. Runs strong, good mileage, and looks great.
All installs, wiring, maintenance, etc.. are professional.
Only issues that I know of:
- Steering box could be adjusted. I bought the spanner wrench but have not gotten around to doing it yet.
- The overdrive on/off button is a little finicky. It works but sometimes you need to play with it a little. I have a replacement for it.
Overall it is ready for fuel and go.
Price $12,999. I don't have to sell so please no lowballs. I can work on the price a little but am not in a position to give it away.
Truck is currently in the Detroit area but I will be back in the Louisville, KY area in August.
Would consider a trade for a RZR 4 or RZR XP. Not really interested in anything else.
I will also have a full custom tilt trailer for sale in the next couple of weeks. (Custom diamond plate steel, Aluminum Storage, Dual 4" hydraulic cylinders, LED Lighting, 5K torsion axles) It is the real deal crawler hauler and can be seen in the pics below.
Please send me a PM and I will call you back ASAP to answer any questions.
Jacob
New pics added Aug. 3:
jakegp is offline
Old July 28th, 2011, 10:48 AM   #2
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
WOW, very nice set-up.
Price for the trailer?
RIP FULLSIZE4LIFE
SHARPMACHINE is offline
Old July 28th, 2011, 10:59 AM   #3
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
wow, very nice good luck with the sale.
Roadhouse is offline
Old July 28th, 2011, 11:10 AM   #4
jakegp
WFW
jakegp's Avatar
Have not really got to the trailer yet.....It has been a tough enough process just coming to terms with selling the other pieces of my offroad puzzle.
Probably looking at $3,600. It was a $7,800 trailer new (no joke) and is in great shape. I never let it see MI salt.
You won't find anything like it out there. Purpose built for hauling a rig like this. No ramps to pull or fenders to worry about + tons of built in storage for spares, gear and supplies.
PM me if you want more details on it. I don't want to clog up this thread.
I'll start another thread once I have better pics of it.
jakegp is offline
Old July 28th, 2011, 11:20 PM   #5
jakegp
WFW
jakegp's Avatar
bump
jakegp is offline
Old July 28th, 2011, 11:59 PM   #6
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Wow. That truck is fantastic. If i was in a position to buy one yours would be the one. Very nice.
Fullsize4life is offline
Old July 29th, 2011, 12:28 AM   #7
2fst4you
2fst4you's Avatar
What kind of mpgs does the truck get with and without rig?
2fst4you is offline
Old July 29th, 2011, 02:24 AM   #8
Jeepaholc92
Jeepaholc92's Avatar
free bump for an i want but i can't afford, very clean very nice!
Jeepaholc92 is offline
Old July 29th, 2011, 01:21 PM   #9
jakegp
WFW
jakegp's Avatar
Thanks for the kind words.
Truck gets ~ 17.5 empty and 14 with the Jeep.
The 315's and 4.10 gears rob a little MPG but it is a towing BEAST.
Used to pull with a 7.4 gasser - night and day.
jakegp is offline
Old July 29th, 2011, 02:40 PM   #10
2fst4you
2fst4you's Avatar
thats pretty good does actually for being on 35s whats are the rpms at around 70-80 mph?
2fst4you is offline
Old July 29th, 2011, 03:46 PM   #11
jakegp
WFW
jakegp's Avatar
~2100 @ 70
jakegp is offline
Old July 29th, 2011, 09:51 PM   #12
2fst4you
2fst4you's Avatar
That's pretty low seems like 4.10s and 35s are perfect on that truck I hope I can get a loan if not goodluck on the sale
2fst4you is offline
Old July 30th, 2011, 10:56 PM   #13
jakegp
WFW
jakegp's Avatar
Up
jakegp is offline
Old July 30th, 2011, 11:13 PM   #14
Fullsize4life
Kicking Cancers ASS
Fyi mine with 285-70-17s and 3.55s is at 1900 at 70 and i can pull 16-18 with my tj on the trailer. So this is pretty average in the mpg area. Granted mine is a 12v. This is one of the nicest dodges i have ever seen.
Old July 31st, 2011, 10:14 AM   #15
Deaner
lost
Deaner's Avatar
Send a message via AIM to Deaner
why part of KY you from?
Originally Posted by Toolmakerprevo View Post
Well at least I can screw comfortably in a bathtub!
Originally Posted by Nuggets View Post
Half you guys bitchin' about these women are probably dragging home snow cows and tundra pigs from the bar.
Deaner is offline
Old July 31st, 2011, 04:36 PM   #16
jakegp
WFW
jakegp's Avatar
From Louisville but am living in Oxford MI.
Truck is in MI right now.
jakegp is offline
Old July 31st, 2011, 04:52 PM   #17
Deaner
lost
Deaner's Avatar
beautiful truck and good luck i'm from Louisville myself!
Deaner is offline
Old July 31st, 2011, 09:53 PM   #18
mikes06cbr
mikes06cbr's Avatar
please call me 586-557-9360 need some info and can you emaol me some more pics???
mikes06cbr is offline
Old August 1st, 2011, 08:21 PM   #19
jakegp
WFW
jakegp's Avatar
Awn Up
jakegp is offline
Old August 3rd, 2011, 09:42 AM   #20
jakegp
WFW
jakegp's Avatar
New pics added in original post.
jakegp is offline
Page generated in 0.33483 seconds with 83 queries
